Need a DC power supply - amplifier?
A user is exploring the idea of creating a DC power supply for a Leach amplifier project instead of purchasing one. They plan to utilize existing DACs and ADCs with a simple program to generate a sine wave, along with building a full-wave rectifier for under $10. Concerns are raised about ensuring the feedback loop's bandwidth, managing inrush current, and using appropriate filter capacitors. While some participants question the practicality and efficiency of this DIY approach, they acknowledge the value of experimentation. Overall, the discussion emphasizes the balance between cost-saving and the potential complexities involved in the project.
280Z28
I need a DC power supply for a project I'm working on.
I have a Leach amplifier with a monster power supply and heat sinks able to handle it clipping at ~500W/channel. It's just sitting on my floor.
I also have a 2 16bit 1MHz DACs and 2 16bit 200KHz ADCs attached to a National Instruments FPGA. I'm thinking instead of buying a DC power supply, I can write a program in 10 minutes that feeds a nice sine curve to the amplifier, and just buy a 2 rectifiers and some caps and build a pair of clean full wave rectifier for <$10 and hook it up to the outputs.
Any immediate reason this is a bad idea? There's no way I'll need more than 2A @ 12V DC from this thing, and it's able to drive a 4ohm load to something like 60+V peak-to-peak, which means 10A @ ~40V DC after a rectifier.
It's going to be the power source for a switch-mode duty-cycle controlled driver for a tiny servo motor (electronic throttle body from a car that I'm testing on my desk).
I assume you'll use the ADC's to regulate the output voltage? Things to pay attention to: A) feedback loop has enough bandwidth and low enough delay. B) you might operate at a high frequency (10kHz, eg.) to reduce size of filter caps. C) calc. inrush current when you turn it on and check it's within amp ratings. Big caps (relative to frequency) with low ESR will initially look like a dead short across your amp.
Done properly you should have a very high-quality supply.
Buy a wall wart from Radio Shack.
Run an extension cord to your car battery.
You're going to deprive 280Z28 (I'm going to guess he's a fan of fast cars) of the immeasurable joys of design and experimentation. He indicated in the OP that he'd like to do this instead of buying a supply. Is it sensible? No. Practical? No. A good use of time? No. That doesn't mean he shouldn't do it :biggrin:
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
