B Need confirmation of planetary distances
  • B
  • Thread starter Thread starter Porsha
    Planetary
The discussion centers on verifying the accuracy of calculated distances for Mercury, Venus, and Earth from the sun, represented in millimeters as a scale where 1mm equals 1 million miles. The user initially presents their measurements but seeks expert confirmation on their correctness. Feedback indicates that while the second number for Venus and Earth represents the semi-major axis, the first number is inaccurate, as both planets have low eccentricities leading to nearly circular orbits. The user acknowledges errors in their calculations after receiving input. The conversation concludes with the user expressing gratitude for the assistance provided.
Porsha
Hello.
I'm wondering if my numbers on my diagram are correct. I've drawn the sun to the left of a plain piece of blank printer paper. To the right I have calculated using millimeters mm representing a million miles. 1mm=1million miles. Mercury is two dots to the right that are 36mm-57.9mm to represent the orbital ring distance from the sun based on the orbit being an oval. Each of those numbers are the closest and farthest away from the sun. Venus is to the right of the sun represented as two dots 67.2mm-108.2mm showing the closest and farthest orbiting distance paths. Earth is to the right of the sun represented as two dots 93mm-149.6mm showing the closest and farthest orbiting distances. Are these numbers absolutely correct representations of the distances of the planets Mercury, Venus, and Earth? All of the distances calculated started at the edge of the sun and not the edge of the paper.
I would like an expert only on this subject to confirm these to be accurate.
You really need not be an expert to look up the orbital radius and the eccentricity. For Venus and the Earth, the second number is the semi-major axis, but the first number doesn't make sense. The eccentricity of both planets is quite low.
you have \frac {S_maj^2} {S_min^2} = 1 - e^2
willem2 said:
You really need not be an expert to look up the orbital radius and the eccentricity. For Venus and the Earth, the second number is the semi-major axis, but the first number doesn't make sense. The eccentricity of both planets is quite low and the orbits are nearly circular.
you have \frac {S_{maj}^2} {S_{min}^2} = 1 - e^2
For small values of e you get \frac {S_{maj}} {S_{min}} \approx 1+e[/QUOTE]
where smaj is the semi-major axis and smin the semi-minor axis, and e is the eccentricity.
e = 0.016 for Earth and 0.0067 for Venus.
Porsha said:
Hello.
I have figured out where I have made errors in my figures. Thank you very much for your input.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
