How Do You Calculate Average Volume Charge Density in a Layer of Air?
The average volume charge density in the layer of air between 500 m and 600 m can be calculated using Gauss' Law. The electric fields at these altitudes are 150 N/C and 80 N/C, respectively. The net electric field difference across the 100 m height is 70 N/C. By applying Gauss' Law, the average volume charge density is determined to be approximately 6.17 x 10^-6 C/m³. This calculation is essential for understanding electric fields in atmospheric physics.
  • Understanding of Gauss' Law in electromagnetism
  • Familiarity with electric field concepts and units (N/C)
  • Basic knowledge of charge density and its units (C/m³)
  • Ability to perform calculations involving electric fields and volume
  • Study the application of Gauss' Law in different geometries
  • Explore the relationship between electric fields and charge density
  • Learn about atmospheric electric fields and their implications
  • Investigate the effects of altitude on electric field strength
Students and professionals in physics, particularly those focusing on electromagnetism and atmospheric science, will benefit from this discussion.
kevinf
In the air over a particular region at an altitude of 500 m above the ground, the electric field is 150 N/C directed downward. At 600 m above the ground, the electric field is 80 N/C downward. What is the average volume charge density in the layer of air between these two elevations?
the answer is supposed to be in C/m^3. i have looked at this question for a long time now and can not find a way to solve it. i think this problem would be easier if the volume of the slab of air of 100m height can be calculated and then use Gauss' law. but other then that i can not think of any other way to solve it. can anyone help me?
Well that is what you want to do isn't it?
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html#c2
Apply Gauss Law. Say you have a 100 x 1 cubic meter closed surface with field lines only going through 2 surfaces - top and bottom.
Isn't the net flux the charge inside, and the charge per cubic meter would be 100th of that?
so should i just kind of make up a volume since it apparently isn't important?
It does make a difference.
The only information you are given are for the horizontal surfaces at 500m and 600m. You can ignore the vertical surfaces because the dot product of the E field and the vertical is 0.
You have 150/m2 at the bottom and 80/m2 at the top.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 24 ·
