Need Help Determining Continuity of Functions
6 replies · 2K views
CJ256
Ability to graph functions.
Essential Discontinuity:
Jump discontinuity or Infinite discontinuity
First Question:
After plugging in 2 for every equation and getting a result that was greater than 0, I determined that the function was continuous and that the type of discontinuity is Essential (Infinite) discontinuity. The reason why I chose infinite is because when I drew the graph on my TI-84 Plus it didn't seem to have an empty point and all my points that I tested were filled. I don't understand how graph them by hand. I usually have no problem solving this type of questions when I have a graph, but when I have to make my own I really struggle.
Second Question:
After testing a couple of values (I tested, -1, 0, 1 as possible values of A) I determined that the answer to the question is all negative values could be values of A. I really struggled with this because I did not understand what the question really asked me. I kind of tried to satisfy the equations and once I saw that it did I decided that that was the answer. I know this question is wrong so any help would be really appreciated.
SammyS said:
Do you have a definition for a function being continuous a point ?
If so, what is that definition?
Yep. A function f(x) is continuous at x = c if, as x approaches c as a limit, f(x) approaches f(c) as a limit or in other words this:
So, first of all [itex]\displaystyle \lim_{x\,\to\,c}\,f(x)[/itex] must exist. If it exists, then it must be equal to f(c).
First Problem: What is [itex]\displaystyle \lim_{x\,\to\,2}\,f(x)\,?[/itex]
How do you determine whether or not this limit exists?
Second Problem: [itex]\displaystyle \lim_{x\,\to\,3}\,f(x)\,?[/itex]
How do make sure this limit exists?
How do make sure this limit is equal to f(3)?
What is f(3)?
What is f(3)?
Well for the first one if I plug in 2 where I have x all the equations are true except the x^3-3 so does that mean that it is not continuous even though it in the second equation 2=2?
For the second one I still have no clue where to start.
Ok so for the first problem, I got that the function exists because of the piece wise function two of the functions equal 5 but I still need help with the second question
It's not asking if the function exists. It's asking if the limit exists.
It's quite clear from Post #5, that you don't understand the piecewise definition of a function. What are each of the following for the first function?
f(-1) =   ?  
f(0) =   ?  
f(1) =   ?  
f(1) =   ?  
f(1.9) =   ?  
f(2) =   ?  
f(2.1) =   ?  
f(3) =   ?  
f(4) =   ?
