Need help figuring out this forces question
The discussion revolves around a physics problem involving two forces acting on an object at a 75-degree angle, with one force measuring 195N and a net force of 225N. A participant attempts to calculate the second force but consistently arrives at 30N, while the expected answer is 72N. Suggestions are made to clarify the approach by drawing a vector diagram and labeling the forces to better visualize the problem. The importance of accurately representing the forces and their directions is emphasized to resolve the discrepancy in calculations. A clear understanding of vector addition is crucial for finding the correct second force.
m_t
the question states: "wo forces act on an object at an angle of 75 degrees. One force is 195N. the net force it 225n. determine the second force that it makes with the net force"
I tried finding the second force by finding the two forces for the final force and subtracting by the two forces from the first force (by two forces i am referring to the direction they are going, in his case, i assumed they wen east and north). then using that answer, i found the original force (hypotenuse). However, and after redoing my calculations three times, i keep o getting 30N, while the answer states 72N
Your first statement in the attempt at a solution is very confusing. You should draw the diagram, give names or symbols to the forces, and then restate what you have done.
Why don't you try to draw a vector diagram and make a closed triangle from the three forces?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
