Need help in manipulating rational absolute value inequalities
The discussion revolves around manipulating rational absolute value inequalities, specifically transforming the inequality |x-3|<1 into a form involving |x+3| and a denominator of 5x². Participants are exploring how to properly handle the inequality while introducing additional variables and ensuring the correct direction of the inequality.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of bounding the numerator and denominator separately versus as a single quotient. There are questions about the legality of these approaches and concerns about changing the inequality direction when introducing new terms.
There is ongoing exploration of the algebraic manipulations involved in bounding the terms. Some participants suggest that bounding the numerator and denominator separately is valid, while others emphasize the importance of maintaining the integrity of the inequality. Clarifications and corrections are being made as participants refine their understanding of the problem.
Participants note that the discussion is not for homework but relates to bounding terms for epsilon-delta limit proofs. There is an emphasis on the need to exclude certain values, such as x=0, and to consider the positivity of terms like 5x² during manipulations.
bamajon1974
For context, this question is not for homework but in reference to bounding terms for epsilon-delta limit proofs. I know you can bound the numerator and denominator separately but I really would like to know how manipulate the quotient together as I have forgotten some elementary algebra.
Please see below.
How does one manipulate rational absolute inequalities?
For example, I want to transform the absolute value inequality ##|x-3|<1## to ##\frac{|x+3|}{5x^2}<A \ ##, for some number ##\text{A}##, to find an upper and lower bound on the latter term using the constraint in the first term, and not sure what to do with the denominator and changing inequality direction.
I can expand the absolute value inequality as follows: ##|x-3|<1 \implies -1<x-3<1 \implies 2<x<4 \implies 5<x+3<7. ## How do I introduce the ##5x^2## term in the denominator? Dividing all three sides by ##5x^2## would add a variable to the numbers and possibly change signs. Not sure where to go from here.
Thanks!
Your lower bound for ##x## implies an upper bound for ##\frac 1{5x^2}##
bamajon1974 said:
Dividing all three sides by 5x2
Sounds like a bad idea. since ##5x^2## is positive (*), multiplying seems more logical: ##|x+3|<5x^2## and you have to study two cases:$$x\le-3 \ \& \ 5x^2 +x+3>0 \quad \Rightarrow x\le -3$$and$$
x>-3 \ \&\ 5x^2-x-3 >0 $$which requires solving a quadratic equation
(*) Edit: Oops, have to exclude ##x=0## :smile:
I made a mistake and ##\frac{|x+3|}{5x^2}<A## for some number A to be determined, not 1.
I am guessing you would have to consider the numerator and denominator separately. So for the numerator, ##5<x+3<7## and for the denominator, ##\frac{1}{80}<\frac{1}{5x^2}<\frac{1}{20}.##
Then, can I combine the two expressions, i.e., ##\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20}## and, to find an upper bound? That is, to produce ##-\frac{7}{20}<\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20} \implies \frac{|x+x|}{5x^2}<\frac{7}{20}?## It seems arbitrary to separate the numerator and denominator.
Thanks.
I made a mistake in the original post and corrected. What I want to do is use $$|x-3|<1$$ to bound ##\frac{|x+3|}{5x^2}## and equal to some number.
bamajon1974 said:
I made a mistake in the original post and corrected. What I want to do is use $$|x-3|<1$$ to bound ##\frac{|x+3|}{5x^2}## and equal to some number. Does that clarify?
What's not clear is why this is an issue. Bounding both is precisely what you want to do.
Ok then I should clarify...I understand the process of bounding. The question I have is the algebra involved in bounding, i.e., is it legal to find the bounds f the numerator and denominator separately or as a single quotient. In the end, I found my bounds but the issue was just a side question I asked,
Remember that ##|a| |b|=|ab|##.
Therefore, ## \displaystyle \left| \frac{1}{5x^2} \right| |x+3| = \left| \frac{x+3}{5x^2} \right| ##.
bamajon1974 said:
is it legal to find the bounds of the numerator and denominator separately or as a single quotient.
Whatever works best. As long as you follow the rules of algebra there's no issue.
By the way, it's often possible to simplify these calculations by taking a round number as the bound. E.g. If we have ##2 < x < 4##, then ##\frac 1 {5x^2} < \frac 1 {20} < 1##.
And, as ##| x + 3| < 7##, we have:$$|x - 3| < 1 \ \Rightarrow \ \frac{|x + 3|}{5x^2} < 7$$Which is just as good as ##\frac 7 {20}##.
I think I see now. Equivalently, ##|a/b| = |a|/|b|.## In the context of my question, it is ##|a|/b##, since ## |a|=|x+3|## and ##|b|## is ##|5x^2|=5x^2## which always positive. Given that ##|x-3|<1## and ##|a/b| = |a|/|b|.##, I can find upper and lower bounds of the numerator and denominator separately and combine them back into one single absolute value inequality, right?
Maybe something like this?
If $$|x-3|<1, $$ then $$|x-3|<1 \implies -1<x-3<1 \implies 2<x<4 \implies 5<x+3<7$$ for the numerator and $$\frac{1}{4}<\frac{1}{x}<\frac{1}{2} \implies \frac{1}{16}<\frac{1}{x^2}<\frac{1}{4} \implies \frac{1}{80}<\frac{1}{5x^2}<\frac{1}{20}$$ for the denominator.
Dividing produces $$\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20} \implies -\frac{7}{20}<\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20} \implies \frac{|x+3|}{5x^2}<\frac{7}{20}.$$
Yes, that's the idea.
