Need help on designs of Fettucini Bridge, by Thursday
  • Thread starter Thread starter RUP2006
    Bridge
The discussion focuses on a project to design a Fettucini Bridge that must hold over 3 kilograms using 20 pieces of fettucini and 1 meter of masking tape. The main advice emphasizes the importance of testing multiple designs to identify and strengthen weak points in the bridge. Participants suggest researching basic bridge principles from various online resources for guidance. Due to a tight deadline, the original poster expresses urgency for replies before the project is due. Overall, experimentation and adaptation are key to improving the bridge's design.
RUP2006
Hi!
I'm currently doing a Fettucini Bridge project...
The material allowed:
20 Fettucini
Purpose:
to hold more then 3 kilograms
Please Help me~~~~
I need the replies by Thursdays.
Thanks to anyone who takes time to read this message.
Actual pictures are perfered...
I had a similar project a few weeks ago. I didn't do too well on it... :frown:
The only advice anyone can give you is test, test and test! Make lots of bridge designs, testing them with weight, and then fix the sections that are the weakest. The more you do this, the better your bridge. Don't just do one design, you'll want to try many.
That being said, you can still have a look around for some basic bridge designs. Read through these sites:
http://www.42explore.com/bridge.htm
http://abcdpittsburgh.org/kids/kids.htm
They give some basic principles for strong bridges, which you can apply to your bridge.
Good luck!
Andy
AMW Bonfire
Thank you very much fore replying...
However, I don't have time now, since its due tomorrow.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
