Need Help Regarding a U Shaped tube problem
  • Context: High School
  • Thread starter Thread starter AmirWG
    Pressure Tube
The discussion revolves around a U-shaped tube problem involving fluid pressure at different points within the tubes. Participants explore the relationship between pressure and height in fluids, particularly in the context of fluids with different densities, such as oil and water.
  • Some participants question why the pressure at point A is less than at point B, given that they are on the same horizontal plane.
  • There is a request for a formula that describes how pressure changes with height, specifically involving fluid density, gravity, and height.
  • Some participants note that if the tubes are open to the atmosphere, the pressure at the top of each tube equals atmospheric pressure, but the heights of the fluid columns differ due to varying fluid densities.
  • One participant suggests that the pressure difference is due to the height difference between points A and B, while another challenges this by stating that both points are at the same height.
  • There is mention of the expression ##\rho gh##, indicating a reference to the hydrostatic pressure equation.
Participants express conflicting views regarding the pressure at points A and B, with some asserting they should be equal due to equal height, while others argue that the differing fluid densities and heights must be considered. The discussion remains unresolved.
There are limitations regarding the assumptions made about the fluid densities and the heights of the fluid columns, which are not fully clarified. The discussion also relies on the understanding of hydrostatic pressure principles.
AmirWG
my text box says that the pressure at point A is less than pressure at point B
Are not they supposed to have same pressure as they are on the same horizontal plane ?
How does pressure change with height? Do you have a formula handy? One involving the fluid density, the acceleration of gravity and the height of a section of fluid, perhaps?
Assuming the tubes are open to the atmosphere, the pressure at the top of each tube equals the pressure of the atmosphere. But note that the tops of the tubes are not at the same level? Evidently the two fluids in the tubes have different densities!
the only thing given is that the fluid in yellow is oil while the one in blue is water.
so the pressure at point A is less than pressure at point B because the height at point B is greater than the height at point A ? right ?
No. Points A and B are at the same height. Are you familiar with the expression ##\rho gh##?
  • · Replies 48 ·
  • · Replies 19 ·
  • · Replies 29 ·
