Need help with a planet....and other questions
  • Thread starter Thread starter KristijanT
The discussion centers on creating a fictional planet with boron-nitrogen-based life and ammonia as a solvent, highlighting the challenge of explaining the planet's boron abundance. Cosmic ray spallation is identified as a potential source for boron, where high-energy cosmic rays can create boron from heavier elements, suggesting that proximity to supernovae could also contribute to boron levels. The impact of a cold, dark environment on the senses of life forms is debated, with considerations of how limited light could shape their evolution and intelligence. Additionally, alternatives to oxygen for respiration are explored, with nitrogen-phosphorus biochemistry proposed as a possibility. Ultimately, the conversation emphasizes the need for plausible scientific grounding while crafting an engaging narrative.
KristijanT
Hi!
So...as you can see from the title,I'm having a problem with an alien planet in a story I'm creating,but not one you'd think would be:
The planet harbours boron-nitrogen-based life with ammonia as a solvent.The only problem in this is:
Boron is scarce.So,I need help in terms of making up a plausible reason for boron to exist in large quantities on that planet.I read somewhere(can't remember where) that "this problem can be largely solved by star systems with increased levels of cosmic ray spallation." Can someone explain what does this exactly mean? Yes,I have searched it up,and,unfortunately,since English isn't my first language,Wikipedia wasn't kind to me with all of its complex terms! So,any help would be greatly appreciated!
Oh -- and,that being said -- it would be of great help if you could give me your opinion on two questions I'd like to ask you!
-The planet being cold(for obvious reasons) and dark(but not entirely dark) -- how do you think that would influence the senses of the living beings on the planet? I'm also planning the planet to have one intelligent alien civilization,so how do you think the environment would influence them too?
-Which element do you think would be most plausible as an alternative to oxygen on the planet?
That's all,thanks guys.
High-energetic cosmic rays can split up nuclei and produce boron out of heavier elements.
In the solar system, there are about 30000 atoms of carbon for every atom of boron. And we have cosmic rays as well. I don't see how this works out.
Even on Pluto (where ammonia freezes), the days are significantly brighter than an Earth night with a full moon. Eyes are useful on the surface as long as the atmosphere is not completely blocking light.
I don't know your BN-based life.
I am not an astronomer or physicist but the below is what I have found and what might be the possible source of the Boron you need for your planet.
spallation
A type of nuclear fission reaction in which cosmic rays of light cause a nucleus to emit a large number of nucleons (protons and neutrons), leading to the formation of new elements (nucleosynthesis).
nucleosynthesis
The formation of heavier elements from lighter elements by nuclear fusion in stars.
From other sources I found:
1. Basically, at this time Boron can only be created inside the supernova of a star.
2. The small amount of Boron on our planet was formed during the very early stages of the creation of our universe.
From this information, I might suggest that there may be two reasons why your planet could possesses a large amount of Boron:
1. Your planet was formed during the early formation of our universe when there was much more free Boron to be gathered during the planets formation.
2. It was near enough to a supernova to have been bombarded with a large number of boron modules ejected from the supernova while the planet was forming around another star.
In either case, there should also be a large number of other heavy radioactive elements from the supernova on the planet as well; and, that might also lend to your story.
For example,: Only a civilization of creatures composed of stable heavy elements should be able to survive on a planet with a very high level radioactivity level from the those radioactive elements.
I hope this give you some help with your problem.
Likes Hornbein
The fraction of heavier elements increases over time. The big bang didn't produce boron, you need stars producing carbon, ejecting this, and then cosmic rays making boron out of it. That process needs time.
Why? Radioactivity can be dangerous to life on Earth because it breaks chemical bonds. Those chemical bonds are (in general) stronger for lighter elements.
I stand corrected regarding my comment regarding the creature survival issue, I expanded a biological survival beyond its application without realizing it.
With regard to my comment regarding the early formation please see the multiple statements in the below Wikipedia reference, although you may consider an unreliable source.
https://en.wikipedia.org/wiki/Cosmic_ray_spallation
Thanks for the answers,guys!
So,to make a consensus regarding a reason for boron to be abundant on a planet,the first reason you mentioned can or cannot be considered as plausible(for use in fiction,atleast)?
Also just to note: I'll actually need two planets based on the same biochemistry(boron-nitrogen,ammonia) that will be very distanced between themselves(with,for example,Planet 1 being far closer to Earth,than Planet 2).
What do you mean by alternative? Do you mean a respiration requirement? An erstwhile oxidizer?
What makes you assume it needs either? You'd have to figure out what the BN cycle needs as fuel source.
"What do you mean by alternative? Do you mean a respiration requirement? An erstwhile oxidizer?"
By alternative,I meant a respiration requirement.
"You'd have to figure out what the BN cycle needs as fuel source."
That would be the case if I:
1.Had a good scientific knowledge(I don't.)
2.Was more focused on the science,instead of the story.Note that what I'm trying to do here is to just inject that bit of plausability into the story,without having to do heavy research.
At this point, I have seen several references that indicate that indicate that No. 1 and No. 2 are reasonable scenario for a high boron level at least for the purposes of science fiction. For example, the below indicates a large amount of Boron in interstellar gas and dust. At the same time, I cannot claim any personal level of knowledge on this subject, everything I am presenting is strictly what I have been able to find on Internet reference sites.
A star gains heavier elements by combining its lighter nuclei, hydrogen, deuterium, beryllium, lithium, and boron, which were found in the initial composition of the interstellar medium and hence the star. Interstellar gas therefore contains declining abundances of these light elements, which are present only by virtue of their nucleosynthesis during the Big Bang. Larger quantities of these lighter elements in the present universe are therefore thought to have been restored through billions of years of cosmic ray (mostly high-energy proton) mediated breakup of heavier elements in interstellar gas and dust. The fragments of these cosmic-ray collisions include the light elements Li, Be and B.
Nothing there states that the production rate or even the accumulated amount would reduce over time. More boron is produced than destroyed, so the amount of boron is constantly increasing (but so is the amount of other elements other than hydrogen).
OK, that makes sense.
On that basis it would seem to follow that, contrary to my statement about the early formation of the planet, in fact, the later the planet's creation the more boron would be present on the planet; because over time a greater accumulation of boron would accumulate in the interstellar dust and gases from the combination of the early creation plus any intervening supernovas in the vicinity of the plant before its creation.
"...in fact, the later the planet's creation the more boron would be present on the planet"
Then,since my story is set in the present,the question,I guess,would be:Was boron abundant enough in the universe some few billions of years ago to create a planet?
I think the answer may not...well,make me happy haha.
I think the low level of boron on our own planet Earth answers that question for you.
Yep.Pretty much.So,well...I guess,the conclusion is that there is absolutely NO plausible reasons for a significant amount of boron to exist on a planet...
When we're talking about alternative biochemistries though,what do you think about nitrogen-phosphorus-based one instead?
I am not going to be any help on this issue. My specialties definitely do not include any elements of chemistry or potential inorganic life forms!
Haha,okay! Nonetheless,thanks for trying to help.
Have you checked wiki:
https://en.wikipedia.org/wiki/Hypothetical_types_of_biochemistry#Ammonia
Are you creating a planet or a moon? Moons are trendy in this seasons ;) and in this case a moon orbiting a gas giant would be ultra plausible.
However, if you are following your variant I'd add two important things:
-heavy radioactive elements tend to decay during billions of years
-heavy elements (especially if planet become melted because of some... nuclear decay ;) ) tend to drown to the core of planet
(damn it... I would not be afraid radiation... just evaporating billions year earlier because of thermal heating of some volatiles like... ammonia would seem for me a more inconvenient part)
So the result that I would see, would be in such case rather stratified planet, with unusually high density in comparison to nearby ice balls.
"Have you checked wiki:
https://en.wikipedia.org/wiki/Hypothetical_types_of_biochemistry#Ammonia ? "
Yep,I have checked it.What I am,though,struggling to think of,is how most of what is said on it would affect the actual life forms.
"Are you creating a planet or a moon? Moons are trendy in this seasons ;) and in this case a moon orbiting a gas giant would be ultra plausible."
I want it to be a planet,actually,but a moon is no problem either!
And...last,but not least,I don't know if I really have a choice,but I don't really want to mess with the radioactivity stuff -- it just adds more and more complications that I would need to research etc.
So,to say it again:I'm aiming for a planet,which is based on an alternative biochemistry(preferably boron,and DEFINITELY not silicon).
Ideas:
1) Very slow metabolism? That would affect reaction time.
2) Easy flight, if your planet resembles Titan: https://en.wikipedia.org/wiki/Titan_(moon)
3) Very little light for photosynthesis or analogous process (roughly counting, judging from Saturn distance 1/81 or 1/100) Expect desperate fight for light and poor environment that is not able to feed many animals per square kilometre.
4) Ammonia is good solvent of many salts, no idea how that would affect the environment. Just possibly you can get some salty ammonia and fresh ammonia, no idea what your organism would like.
5) Still thinking how to get this boron...
That would,unfortunately,pretty much undo the story I want to create! Instead of the very slow metabolism,I think a slower evolution process would do the job.
I think making the autotroph organisms dark would solve atleast a bit of that problem,no? And with the biochemistry being totally different,could there be ways around this problem? I really don't know what I am talking about,just asking if the biochemistry being different could affect/solve much of the problem.
And...I actually have an idea around this,but it's some really really really(multiply "really" by how much times you wish) fictionalized one.
It involves an ancient alien civilization(one which will have its role in some big parts of the story) heavily influencing the planet's biochemistry while the planet is still young.Not plausible?Nope?Not a tiny bit? Yep,thought so.
You know the rule of thumb that reaction speed slows down by factor of 2-3, with each ten Celsius degrees less?
https://en.wikipedia.org/wiki/Q10_(temperature_coefficient)
Slower evolution? So your planet is ex. 8 bln years old? Then make the star small, as big stars tend to cause problems related to luminosity change during its lifetime.
Your idea is to:
a) really make an original and more or less realistic ammonia / boron based life?
b) place Earth like life to such planet and purely for flavour purposes claim that it uses alternative biochemistry?
No, it's not an aggressive question, but more a question what are your needs.
I heard this idea of black plants, but I personally consider this idea as too lucky to be true. On Earth quite a few different strategies were used, some underwater plants really needed light sensitive substance and failed evolving that. (disclaimer: my private opinion and not law of nature)
Suggestion: what about just trying to follow weird implications from such planet? I thought that's where the fun start... So for example you end up with small, low gravity planet, where trees grow for millennia to reach hundreds of meter and put its competitors in shadow?
Deus (Alien?) ex machina? Maybe before resorting to that let's think first about some lucky list of events that lead to desired result.
I'd think more about one thing - on Earth cyanobacteria caused havoc by producing all that oxygen. Maybe you'd think about similar event on your planet?
Additional issue - have you thought about your planet temperature / composition? Like don't know crust made of water ice, on top of which all this ammonia is flowing?
Czcibor said:
Your idea is to:
It's not an aggressive question,in fact I'm rather glad that you asked,otherwise I don't really know if I would have brought it up! My needs are these:
-- Yes,I need an original and intelligent ammonia/boron-based life.And I need decent reasons for it to happen! And,since boron is actually scarce in the universe,I was hoping such planet would be such a rarity that there would be few such planets in the observable universe.(since the plot is also a human helping them find another planet after their home has become non-habitable -- and well,I'm kind of worried about revealing too much,so I guess that's enough revealing...or?)
That's actually a nice idea,and,though,as I said above,it'd have to add up to a planet that harbours intelligent life.Though,wouldn't that cause a problem -- since we know that ammonia has a melting point of -78 C and a boiling point of -33 C,so if the planet was to be a low-gravity one,wouldn't that make its temperature span of liquid state even smaller,like,too small for a stable environment?
Yeah,that's also a very nice idea! So,you're implying that there could be,a similar organism on the planet that could produce big amounts of boron and literally change the planet.Well,all good,I guess...haha.No,but,in all seriousness,I don't know...do you think such event would be really plausible?
The planet temperature -- yep,I've thought of it.I actually thought of the planet to be a bigger one than Earth,around 1.5-2 times bigger,so that would wide up the temperature span of the liquid ammonia than what it is on our planet,right? (I don't know how much to be exact,but it won't really be much,I guess?) Also,liquid ammonia on top of water ice...oxygen in a ammonia environment doesn't seem to me like a good idea...?
The boiling point of ammonia depends on pressure. Increase pressure and you get a larger range.
OK. Gottcha.
I thought about this boron origin:
-Realistically, it must have been created billions of years earlier, so not much evidence would be left anyway.
-If it was created by cosmic radiation, then by the same process also plenty of lithium and berilium created. So it means that those 2 elements are much more abundant than usual, and that's mostly the only trace left. Radioactive elements already passed away.
(If the planet is older than Earth, then it has got less U-235. If it has got more lithium it means, that maybe nuclear fission would be harder to provide, but fusion - easier ;) )
As MFB said - boost atmospheric pressure. You would get it liquid in bigger temperature range.
I'm afraid - not specially. But you don't need that anyway.
Free oxygen may react, water ice - not specially. I would not neglect also carbon dioxide. It would be gaseous or condense on ice caps.
Dunno about this size. I would think that small light ice ball is funnier, as it allows easier flight and easier space travel.
Could the boron have been dumped there billions of years ago by a primordial civilization as a waste product? But more specifically, why does boron matter to your story? There are plenty of other atoms that are capable of creating genetic codes, and some are far more abundant than boron.
Well, that article only lists three, one of which the OP has already disqualified (I believe because it's been overdone). The only one left is sulphur.
Uhm...what did you mean by this?
Yep,will do so.
Yep,it could of course -- but as Czcibor said,it would be a deus ex machina,right? Though,since an ancient alien civilization IS playing a part in my plot,if I'd explain their motives in doing so(affecting the planet's biochemistry),I don't think it would still be deus ex machina.(?)
Because,while searching for an alternative biochemistry,boron was just the perfect match.Why?
- For plot reasons,I need the aliens' planet to be rare.Boron just fits into this.
- I've considered silicon,but there are too many problems listed for such biochemistry to happen,and it's already unoriginal(simply,overdone in fiction) too.
- I didn't find any information(which would be valuable) about any other biochemistries(nitrogen-phosphorus,sulfur...)
- I still haven't found(although,from the very little information I got) any problems for a boron-based biochemistry rather than boron being scarce.
There was an event billions year earlier that caused this irradiation. When your story is set it is impossible to figure out what exactly has happened, as data is inconclusive. Maybe black hole jet? The only thing that's left is this radiation caused cosmic ray spallation, and in order to make everything scientific sound make a bit unusual ratio of other elements / isotopes just to fit that.
It's more a matter of your story. I was afraid that you need some ancient aliens to just appear out of nowhere, change planetary composition and disappear. ;) If you have more story use for them, then it's not so bad. Personally, I'd still opt for lucky natural causes for this planet formation. Then you would not have to worry how much overkill is a civilization that was running huge terraforming projects billions of years ago.
Likes BiGyElLoWhAt
Meaning that the planet should also have plenty of lithium and beryllium,then? Though,would this abundance of those elements have some greatly characteristic effect on the planet...or?
Yep.I have a good story use for them,so I'm still thinking of that idea.Though,I might just make it a combination of both(don't ask me how haha -- I don't know! Though,I'll definitely spend some time on thinking it through).Anyway...I still have ton of questions(which I didn't post because I thought it'd simply be too much of...overloading of questions).I should continue posting them on this thread,I guess...?
For planet as whole - I don't see it. Lithium salts are used as psychiatric medication, but presumably that don't fit boron based law... ;) Nevertheless, pending on tech level, because of lack of deficit heavier elements (ice ball, right?) there would be a problem with fission based power plants/weapons, while fusion would be supported by huge quantities of lithium.
Lithium batteries? ;)
Does your space ships use nuclear fusion?
  • #31
While I have come up with a (very fictional,though) concept that will allow space-travel between huge distances,to be honest,I haven't thought about how would a spaceship work! Lithium,would,I guess,play a big part in this,but what about beryllium,too?
  • #32
Seems that can be used:
https://en.wikipedia.org/wiki/FLiBe
For me lithium looks like obvious choice in fusion, while beryllium is a merely one of many possibilities.
How would a spaceship work? Either in way that violates a few laws of physics or in a way that would make your readers fall asleep. :D
(yes, that's how it works in SF...)
  • #33
I'd rather choose the first!
Though -- shielding from radiation would also be needed.Boron nitride shows great promise here.
To quote Wikipedia...: "Like BN fibers, boron nitride nanotubes show promise for aerospace applications where integration of boron and in particular the light isotope of boron (10B) into structural materials improves both their strength and their radiation-shielding properties; the improvement is due to strong neutron absorption by 10B."
en.wikipedia.org/wiki/Boron_nitride#Boron_nitride_nanotubes
Also -- what do you think about solvated electrons being an energy source on the planet? Check this out.
www.newscientist.com/article/dn25894-meet-the-electric-life-forms-that-live-on-pure-energy/And,finally.About boosting atmospheric pressure -- I don't know how much would be sufficient enough for,liquid ammonia,to have,for example,a temperature span of 80-100 C(-77 C to 3-23 C).
  • #34
I tried to find a nice phase graph. I failed
Idea:
http://www.peacesoftware.de/einigewerte/nh3_e.html
Try some values and determine that by trial and error.
EDIT: There is something wrong with this calculator or I operate it incorrectly.
EDIT2:
6 atm would be enough, as bonus it would be liquid under room temperature
  • #35
So...according to this,under a pressure of 10 bars(9.86923 atm) ammonia should have a boiling point of 25 C.That should be ample for life,right?
  • #36
Seems like huge margin.
Under such pressure you can also expect liquid CO2.
One more thing. You wanted a big planet:
f the radius of our planet were larger, there could be a point at which an Earth escaping rocket could not be built. Let us assume that building a rocket at 96% propellant (4% rocket), currently the limit for just the Shuttle External Tank, is the practical limit for launch vehicle engineering. Let us also choose hydrogen-oxygen, the most energetic chemical propellant known and currently capable of use in a human rated rocket engine. By plugging these numbers into the rocket equation, we can transform the calculated escape velocity into its equivalent planetary radius. That radius would be about 9680 kilometers (Earth is 6670 km). If our planet was 50% larger in diameter, we would not be able to venture into space, at least using rockets for transport.
That was calculated for Earth composition, sure. Your ice ball would be lighter, I assume, nevertheless...
http://www.nasa.gov/mission_pages/station/expeditions/expedition30/tryanny.html
  • #37
Good thing,bad thing(or...uhm,neutral thing)? :D
Well,if it would be a problem,to be honest,that could very easily change!
Well,I don't imagine the planet as an ice ball...but,nevermind -- so a big(ger than Earth) planet isn't a problem,then?
  • #38
Mountain glaciers of dry ice, that actually melts, flows downstream and evaporates before reaching sea level? Sounds interesting.
One issue. For my purposes I consider as cool building a planet that is weird and all weirdness is perfectly according to laws of physics. That civilization had to be built in different way, not because of any choice but because of environmental determinism. On the other hand when I discovered such stuff too late, it required some rewriting.
Actually big rocky planet can work. And you can be delighted that local civilization haven't sent a space rocket before invention of fusion nuclear engine. Because of dense atmosphere they may had problems to see stars at all, so they may have started creating rough astronomy as late as during their equivalent of industrial revolution.
Fits your story or not specially?
  • #39
Actually -- I imagined the planet as a...darkish(as I said earlier with the plants being dark to collect more light) with dark-green dots being seen across the lands from Space(that's a...well,special detail :D ),with oceans of brown liquid ammonia(it becomes brownish when it dissolves large amounts of alkali metals).
Interesting,and very cool!(pun intended)
It actually fits my story nicely,and it's definitely a good idea.Now...next thing that could be adressed would be the process of getting energy.As I posted above,maybe solvated electrons that are held in the liquid ammonia could play a big part in this?
  • #40
Right... brown ammonia and no ice caps over oceans... (heavier, sinks)
This part would involve high percentage of handwavium and making stuff up. The only thing that I see here as hard fact - low amount of energy, not so densely populated environment. The rest would be creating plausible story, with very remote contact with hard data. Suggestion: leave it for later, just basing on that that you would finally need.
  • #41
Czcibor said:
...leave it for later, just basing on that that you would finally need.
Well,what I would need is a very very basic explanation on how do the aliens get energy,really.Nothing complex or complicated,just something that could be put in some 1-3 sentences.
Other things I'll need to address: The planet's protection from its host star.On Earth,it is the ozone.On this planet?
I'll also need to create 4 other planets(yep,don't read it again,4 other planets),and I think all of them would be with a biochemistry same as Earth,some with different gravity,and of course,different creatures/environments and all other kinds of differences you can imagine.The positive stuff of this is that I won't need to have much details about the planets because the protagonist won't spend much time on them.
Nevertheless,I won't be focusing on the planets at all before I address all of the problems about the alien planet (with your great help,of course!),create a new element(s) too(they'll have much to do with the ancient alien civilization),and think of an event that will make the aliens' planet(the one we're talking about now) inhabitable -- but due to their only-recently developed(but,nonetheless,much more developed than ours because -- they're much more technologically advanced than us when they start developing it)astronomy they have little time to save themselves and end up doing the decisions that lead to the start of my story.Yep,much work to do,indeed.
Also,at this point,even though there will be much more questions(and hopefully,answers) incoming,I still want to thank you for helping.
  • #42
In non-polar liquid... Hmm...
Requires as water... using some local enzyme produces hydrogen peroxide and dumps hydrogen (lost from the system)? To recover energy first decompose peroxide and later oxidize amonia?
[limited science content, water should be very popular substance especially for such frozen planet, energetically makes sense, peroxide would be frozen and treated as local lard equivalent, no idea whether it would really work]
Make the star smaller:
-would give more time for evolution of those slow species
-would make the star less active in UV
Damn it. I would just feed you with planets that I use:
Amanda:
-binary system, 2/3 of its energy comes from red dwarf that it orbits in slightly above a week (tidal lock), 1/3 in from Sun sized star that is being orbited in 5 years
-terribly frozen, over 60% of surface covered with ice, on the dark side temporary appears frozen carbon dioxide
-oceans 80%
-3 atm
-the only area settled is dry, subtropical region near big rivers (yes, on ocean-ice planet you seek hot and dry place :D )
Mahdi:
-dry planet, water cover below 10% (that actually extends habitable zone, as it harder to achieve runaway greenhouse effect)
-no longer tectonic activity
-minimum axial tilt
-no moon, 14h day
-very hot, only poles are inhabitable
-effectively only one pole settled
USO:
-very young planet 2.5 bln years max
-part of oxygen actually came from water hydrolysis from UV
-already at edge of habitable zone (too hot)
-2 moons, very strong tides
-20h day
-young planet - higher content of U225 to U238 - nuclear fuel does not need enrichment
-too high UV for humans, have to hide for day
JW:
-chthonian planet orbiting white dwarf
-tidal lock
-dense, very rich in metals
-10 km of ice frozen on its dark side, equilibrium achieved because the glacier creeps back and melts
-seas of very high salinity that remain liquid in spite of temp below 0
-only rainy area in the centre is habitable
Viking:
-exomoon, one day (orbit) is 11 days
-sea cover, 70%
-one super continent, effectively uninhabitable
-only inhabitable areas are islands (inside the continent temperature jumps are lethal)
-weird season because of combination of axial tilt and elongated orbit of its gas giant
Octopus:
-4 Earth masses
-very dense atmosphere
-roughly uniform climate below, wet
-strong greenhouse effect
-only habitable areas are mountain ranges
Useful? ;)
  • #43
While I have to thank you for posting planets you already created,and some of the information about them does give inspiration for other ideas,I got to say,that,as I have mentioned in my previous post,most of it would,in my opinion,be too unrelevant to the plot to mention! Though,the mention of binary system just reminded me to an article I have read about a planet in a quadruple star system: now that'd be cool to use!
I didn't quite get you there though...
Actually -- in a reducing atmosphere such as this planet's -- water for the creatures living on the it would be exactly as acid to us.So...I don't think that water would/should be a very popular substance in this planet...
Yeah,sure,though I kinda doubt that it will be enough to shield the planet.
  • #44
It is a practical limit, not a fundamental one. That is the point of staged rockets. The payload to rocket mass ratio goes down, but it does not get impossible.Concerning lithium for fusion: even on Earth we have more lithium than we could reasonably use for tritium breeding in the near future. The hard part is the fusion reactor, not the lithium or deuterium supply.
  • #45
So...question incoming:
What do you think about different-shaped eyes?
No,no,I don't mean different-shaped pupils,but eyes.
  • #46
Why look at what nature already provides?
You can extrapolate from there, but the further you detour from what is proven the more likely you will find errors in your proposals.
  • #47
What for?
I don't see special source of difference here (except maybe a bit less light, a slightly bigger eyes advisable)?
You need some weird stuff for cool factor?
  • #48
Czcibor said:
What for?
Larger eyes are interesting. In one of my books the population genetically modified their eyes to be slightly larger to give their faces a more pedomorphic trait. They simply saw it as a more sexually desirable feature and adopted it as the norm.
So, in some instances features can be artificially enhanced, deviating from the evolutionary norm.
  • #49
And can make the whole planet cute/ turn local population into anime characters. ;)
More seriously, making eyes interesting:
-compound eyes - not specially, may give some minor advantages if the creature used to be a prey;
-different wave sensitivity - maybe - if the star is dimmer, then should see near infra red and can sacrifice violet visibility (drawback - don't visible directly from character, only visible from colors of artificial objects)
  • #50
Haha,nope! For that matter,I actually have a weird enough alien -- I just though that,it's a totally different world,so,there is a good chance that most of the creatures will be very different,eh? Though,of course,I could just put same-looking eyes,and just free myself of complications,but just wanted to put this up here before I do so to have a look at some opinions,and,well,maybe to decide otherwise.
9K
