Need help with explaining surface tension
Surface tension is a property of liquids arising from intermolecular forces that create a cohesive layer at the liquid's surface. It can be quantified using the equation gamma = F/L, where gamma represents surface tension in N/m, F is the force, and L is the length along which the force acts. In the example of a needle floating on water, the surface tension must balance the weight of the needle, demonstrating how these forces interact. Understanding the force diagrams involves recognizing that the tensile forces act tangentially at the surface and are influenced by the bonding between liquid and solid phases. A solid grasp of these concepts will help effectively explain surface tension in a classroom setting.
airforce840
My group is to teach a lesson to our AP Physics class on a lesson from our book. We got lesson 92, which deals with Viscous Fluids, Surface Tension, and Elastic Properties of Solids. Since there's 3 people, we each got one and lucky me got surface tension. I have to be able to discuss this pretty darn throughly, explaining anything about it. I see that there's an equation, gamma = F/L Answer being in N/m 's
I have some info from my book but there is these force diagrams that i have NO clue how I am going to explain, and maybe that's why i think i don't understand this. It gives an example of a needle on top of water. Needle weights .008 N so what's the max. ^ force of the water...it would be .001. This force diagram shows a Tx on both sides of the needle 2 Ty's up and to T's going at feta angle. I don't get that. I understand everything else. Where are all these forces coming from?
Ok, maybe I am making this too complicated...or undercomplicating it. I am not sure. Can someone give me a general info on surface tension so that they can solve problems dealing with them and i not sound like a total moron when up in front of the class?
Thanks in advanced, sry for such a long post..
The force in surface tension arises from the intermolecular (or interatomic) bonds in the liquid phase of a two phase system. These same forces are responsible for viscosity.
As FredGarvin recommended, Hyperphysics is a good starting point.
For a stable bubble, the force created by the gas pressure (inside the bubble) must balance the tension at the surface of the bubble, which is really the interface between gas (or vapor) and liquid phases. The tension has to be in the liquid because there is not contiguous bonding in a gas.
The tensile force also acts tangent (parallel) with the surface of the liquid. Where the bubble attaches to a solid surface, there is interatomic bonding between liquid and solid.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
