Need help with finding angles RE: finding vector components
The discussion focuses on finding vector components and resultant displacement in a homework problem. The user expresses confusion about when to add 180 degrees to angles and how to correctly break down distances into x and y components. They correctly calculated the x and y components for one distance but questioned the angle for a fourth vector, which is confirmed to be 60 degrees from the horizontal. Clarification on angle assignments is sought to avoid mistakes in future exams. Understanding these concepts is crucial for accurate vector analysis in physics.
mizzy
See attached photo. Find the resultant displacement measured from the starting point.
When it comes to angles, i sometimes get confused when to add 180 or not. FOr the first two distances, we don't have to find the components. For the last, we have to break it up into x and y components.
for the third distance:
x component = -150cos30
y component = 150sin30
IN MY ASSIGNMENT, I GOT THIS WRONG.
for the fourth distance:
isn't the angle 60 degrees??
Can someone help me get this straight about assigning angles? I don't want to make a mistake on the final exam.
THANKS
Yes the fourth vector has an angle of 60 degrees from the horizontal. Your work is fine so far.
