Need help with question and checking of answers
  • Thread starter Thread starter rock.freak667
The discussion revolves around solving a physics problem involving the motion of two snooker balls on a table. The primary focus is on demonstrating that cotα + cotβ = 2.5 and tanα = 2, as well as showing that the ball's direction changes by 90 degrees upon impact at point C. Participants emphasize the role of the coefficient of restitution, which only affects the perpendicular component of the ball's velocity during the collision. The conversation highlights the importance of analyzing both horizontal and vertical components of motion to derive the necessary relationships. Overall, the participants are collaboratively working through the problem using geometric and physical principles.
rock.freak667
http://img234.imageshack.us/img234/9536/scan0006hj0.jpg
Two identical snooker balls are at rest at the point A and B of a snooker table, where AB+1m. The liunes AB is aparallel to a smooth side of the table and at a distance of 0.4m from that side. The ball A is projected along the table with a speed of 2ms^{-1} to hit the side of the table at C. It rebounds and subsequently hits the ball at B. The angles that AC and CB make with the table are \alpha and \beta respectively (see diagram). The coefficient of resititution between the side and a ball is \frac{1}{4}. Resistances may be ignored and the balls may be considered as particles.
(i)Show that cot\alpha + cot\beta=2.5 and tan\alpha=2
(ii) Show that the direction of motion of the ball turns through 90 degrees on impact at C
(iii) find the speed of the ball after impact at C.
e=\frac{\delta v}{\delta u}
Well here is my work...in pictures because, typing it up would have taken a long time.
http://img233.imageshack.us/img233/2581/scan0006cb8.jpg
http://img396.imageshack.us/img396/4219/scan0007wu2.jpg
Strangely enough,I had a hard time looking for ways to show that tan\alpha=2
One thing that will help with both showing that \tan\alpha = 2 and finding the speed after impact is realizing that the coefficient of restitution only applies to the component of velocity perpendicular to the surface.
So the perpendicular comp. of the velocity before impact is 2sin\alpha
and the perpendicular comp. of velocity after is vsin\beta
and
\frac{1}{4}=\frac{vsin\beta}{2sin\alpha}
But where would I get the tan from?
Use both the horizontal and vertical components.
2cos\alpha and vcos\alpha, both point in the same direction.
So 2cos\alpha=vcos\beta because the horizontal velocity should stay the same?
Yes. Now relate the tangents by dividing the vertical and horizontal components.
ah thanks, got it there.
