Need vector help tension and magnitude
The discussion focuses on resolving a problem involving two active forces: an applied force (u) and gravity. Tension in the string is identified as the force that counteracts both of these active forces. The solution involves writing out the sum of all forces in both the x and y directions to analyze the system. The original poster resolved their issue independently after seeking help. Understanding the balance of forces is crucial for solving vector problems in physics.
Frenchie
nvm i got it ty!
You have two active force, one is u and one is gravity. Then you have tension in the string that counteracts both those forces. So write out the sum of all forces in the x direction and the sum of all forces in the y direction.
