How Do You Calculate the Third Maximum Position in Single Slit Diffraction?
The calculation of the third maximum position in single slit diffraction using a helium-neon laser with a wavelength of 633 nm and a slit width of 2.2 x 10-5 m results in an angle of 5.7 degrees. The formula applied is Sin Theta(m) = (m + 0.5) Lambda/w, where m is the order of the maximum. Substituting m = 3 yields Sin Theta(3) = 0.1, leading to Theta(3) = sin-1(0.1). This confirms the position of the third maximum is accurately calculated at 5.7 degrees.
  • Understanding of single slit diffraction principles
  • Familiarity with the sine function and inverse sine calculations
  • Knowledge of laser wavelength measurement
  • Basic algebra for manipulating equations
  • Study the derivation of the single slit diffraction formula
  • Explore the effects of varying slit widths on diffraction patterns
  • Learn about the application of lasers in optical experiments
  • Investigate higher order maxima in diffraction and their calculations
Physics students, educators in optics, and researchers interested in wave phenomena and diffraction patterns.
alicia113
A single slit is illuminated with a helium-neon laser whose wavelength is 633 nm. If the slit width is 2.2 x 10 e-5 m, calculate the position of the third maximum in degrees
2. Homework Equations
3. The Attempt at a Solution
Sin Theta(3) = (3 + 0.5)(633 x 10 e-9)/2.2 x 10 e-5
=(3.5)(633 x 10 e-9)/2.2 x 10 e-5
=0.1
=5.7 degrees
Therefore, the position of the third maximum is at 5.7 degrees
is this right?!
=0.1
=5.7 degrees
is this right?!
That looks good to me.
