Net Force: Tension problems with angles
The discussion revolves around calculating the tensions T1 and T2 in a Y-shaped rope system supporting a 100N block. The user attempts to set up equations based on the forces in the x and y directions, noting that T1 is vertical (90 degrees) and T2 is at 58 degrees to the horizontal. An error is identified in calculating T1 due to its angle, which results in a misunderstanding of its x-component. Clarification is sought on how angles are measured and the need for a visual representation of the setup is emphasized. The conversation highlights the importance of accurately defining components of forces in tension problems.
uni777
A rope forms a Y.
At the end of the Y hangs a block with a W= 100N
Whole the two upper ends are on the walls.
(Left side) T{1} with an angle of 90 degrees
(Right side) T{2} with an angle of 58 degrees
Find the tension of each rope on the wall.
No definite formulas
\SigmaFx=T{1}cos90-T{2}cos58=0
Summation of Fy=Tsub2sin58-100=0
=117.92
cos90=0
Which makes the value of T{1} an error.
Where did I go wrong?
Without a picture, it is hard to imagine what is going on. How are the angles measured? With respect to the vertical or with respect to the horizontal?
Oh sorry...
T1 is measured respect to the vertical
T2 respect to the horizontal
As for the picture ill try to provide but erm its like this:
Your left pointing finger must form a right angle with your right pointing finger such that your nails/tips are touching each other.
Then T1 is attached on your left pointing finger.
And T2 is attach on your right pointing finger.
oh its like this but instead of a ninja...its a block
OK. So it looks like in the x-direction you have two components of forces. Since the force on the left T1 is entirely in the x-direction (has no y-component), what is its x-component? What about the x-component of T2?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
