Discover the World of Robotics and Engineering: Tips for Beginners in Korea
  • Thread starter Thread starter jandkas
    Engineering
Robotics and engineering enthusiasts in Korea can start their journey without needing extensive resources like a garage or scrap metal. Joining an engineering club at school is a great way to gain practical experience. For beginners, hands-on learning is recommended over traditional textbooks, with suggestions for simple robotics kits available online. A solar-powered cart kit is highlighted as an affordable option that teaches fundamental concepts. Emphasizing patience, the discussion encourages newcomers to gradually build their skills in engineering.
jandkas
Hello, I am interested in robotics and engineering but since I live in a place like korea, I don't have a garage or access to cheap scrap metal. I am going to join the engineering club at my school. I want to pick up a book something like engineering 101 or robotics for dummies, but I couldn't find it. Could someone help me?
Welcome to the forums! It's good to see that you have so much enthusiasm about Engineering!
Personally, I learn a bit better when I do a hands-on approach rather than reading a "for dummies" book. I suggest picking up a small kit for robotics, something very simple to start with.
http://www.solarbotics.com/product/k_ss/
This looks like a good choice for a new student and is cheap. keep in mind that this is a very simple solar-powered cart that just moves forward, but it will teach you a lot about how to make a simple machine.
Just because you're a mechanical engineer, it doesn't mean you have to own a machine-shop and make carbon-fiber quadrotors right out of the gate. Give it some time! :wink:
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
