Newtonian perturbations to Minkowski
smallphi
The Newtonian gravity limit of GR is represented by a perturbation to Minkowski metric:
ds^2 = - (1+ 2\Phi(x,y,z,t)) dt^2 + (1-2 \Phi(x,y,z,t))(dx^2 + dy^2 + dz^2)
The geodesic equations of this metric correctly reproduce the Newtonian equations for acceleration of a test particle in the gravitational potential Phi:
d^2 x / dt^2 = - \nabla \Phi
The Poisson equation that describes how matter generates the gravitational potential :
\nabla^2 \Phi(x,y,z,t) = 4 \pi \rho(x,y,z,t)
should be derivable from Einstein equations. In Newtonian limit of Einstein equations, we describe the gravitating matter with energy momentum tensor of dust
T_{\mu \nu} = \rho U_\mu U_\nu,
where rho is the matter density.
We have to assume the gravitating matter is moving much slower than light in the perturbed Minkowski coordinates above because only under such conditions the above Newtonian equations apply - they don't show GR or SR effects and behave as if signals propagate at infinite speed. If the matter is moving slowly, the U_0 components of the 4-velocity of gravitating matter will be ~1 and the other components suppressed by v/c, v = coordinate speed of gravitating matter. Correspondingly, the only significant component of the energy momentum tensor will be the T_00 ~ rho and the other components will be suppressed by a factor of (v/c)^2. The same applies to the components of Ricci and Einstein tensors which the Einstein equations set proportional to the energy momentum tensor.
So we expect the above Minkowski perturbed metric to produce Ricci and Einstein tensors with components supressed by (v/c)^2 compared to the 00 component. Let's see if that is really the case. I plugged the above perturbed metric in Mathematica and neglecting factors of second and higher order in phi<<1 I got:
R_{00} = 3 \partial_t \partial_t \Phi + \nabla^2 \Phi
R_{11} = R_{22} = R_{33} = - \partial_t \partial_t \Phi + \nabla^2 \Phi
R_{0i} = 2 \partial_t \partial_i \Phi
and the other components were zero or of second order in phi. The usual saying, neglect the time derivatives because gravitating matter is moving slowly, doesn't work because then R_11= R_22 = R_33 components won't be 'suppressed' but equal to the R_00 component. Requiring R_11= R_22 = R_33 = 0 imposes a wave equation condition on the gravitational potential - gravitational influence propagates at the speed of light. That is OK cause that is what we expect anyways. On the other hand, if we allow for the nonzero double time derivative, we get
R_{00} = 4 \nabla^2 \Phi
instead of
R_{00} = \nabla^2 \Phi
That means the coefficient in Einstein equation which is fixed by the Newtonian limit must be 4 times 8piG instead of 8piG.
I am also not sure how the condition R_0i = 0 should be interpreted ??
The above shows there is something improper in the Newtonian metric above - it either doesn't describe slowly moving dust (time derivatives neglected but R_11 not suppressed compared to R_00) or the coefficient in Einstein equation has to be adjusted to 4 times 8piG (time derivatives not neglected). Anyone knows what the metric must be in more proper treatment of Newtonian gravity, one that takes into consideration finite speed of gravitational influences? Is that 'linearized gravity' ?
I got it. The Einstein tensor components for the above metric are
G_{00} = 2 \nabla^2 \Phi
G_{11} = G_{22} = G_{33} = 2 \partial_t \partial_t \Phi
G_{0i} = 2 \partial_t \partial_i \Phi
the other components are either zero or of second order in Phi. So dropping the time derivatives really shows the 00 component dominates and the others are zero. That was expected because the Einstein tensor is proportional to the energy momentum tensor via the Einstein equations.
The Ricci tensor 00 component is the same as the Einstein 00 after dropping the time derivative. On the other hand Ricci 11, 22, and 33 are not suppressed but equal to Ricci 00, and that is OK because Ricci doesn't have to follow the structure of the energy momentum tensor, only the Einstein tensor has to. That was the origin of the whole confusion.
My calculations with GRtensor agree. The exact expression I get for the time component of the Einstein tensor, G_{tt} is:
<br /> \frac{1}{1 -2\Phi^3} \left[ (2-8 \Phi^2)(\frac{\partial^2 \Phi}{\partial x^2}+\frac{\partial^2 \Phi}{\partial y^2}+\frac{\partial^2 \Phi}{\partial z^2} ) + (3 + 6\Phi) \left( (\frac{\partial \Phi}{\partial x})^2 + (\frac{\partial \Phi}{\partial y})^2 + (\frac{\partial \Phi}{\partial z})^2 \right) + (3 - 6 \Phi) (\frac{\partial \Phi}{\partial t})^2 \right]<br />
(I didn't look at the other components very closely).
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
