Newton's 2nd Law conceptual problem
In summary, the rocket's engines must provide a thrust force of 30,000 N in addition to countering the rocket's weight of 147,000 N to achieve an upward acceleration of 2.0 m/s2. The correct expression for this scenario is F=15000kg*(2m/s^2 + 9.8m/s^2).
[V]
28
A 15,000 kg rocket blasts off from Earth with a uniform upward acceleration of 2.0 m/s2 and feels no air resistance. The thrust force its engines must provide during this acceleration is 30,000 N upward.
Apparently this is FALSE!
I don't understand why
F=MA
[tex]
30000N=15000kg*2m/s^2
[/tex]
indeed the math is true?
why is the answer false? What am I missing? Thanks!
Because you have to also counter the rocket's weight, so the force must be equal to the rocket's weight plus an additional 30,000 N to cause a 2 m/s2 upward acceleration.
(It might be easier to see if you draw a free body diagram)
Expanding cjl's post:
[tex]
[/tex]
is wrong; while
[tex]
[/tex]
is the right expression.
Remember that F in Newton's 2nd law are all the forces that are acting on a body. Thus, besides the upward force, you also have a downward force, which is gravity.
The answer is not false, but the statement may be misleading. Newton's second law states that the net force acting on an object is equal to its mass multiplied by its acceleration. In this case, the net force acting on the rocket is indeed 30,000 N, which is equal to 15,000 kg multiplied by 2 m/s^2. However, this does not mean that the rocket's engines are providing a thrust force of 30,000 N upward. The engines are actually providing a thrust force greater than 30,000 N in order to overcome the force of gravity and accelerate the rocket upward. Additionally, the statement does not take into account the fact that the mass of the rocket decreases as fuel is burned during liftoff, which affects the acceleration. So while the math may be correct, the statement oversimplifies the situation and does not accurately describe the forces at play during liftoff.
1. What is Newton's 2nd Law?
Newton's 2nd law, also known as the law of acceleration, states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. In simpler terms, this means that the more force applied to an object, the more it will accelerate, and the more mass it has, the harder it is to accelerate.
2. What is the equation for Newton's 2nd Law?
The equation for Newton's 2nd law is F=ma, where F is the net force, m is the mass of the object, and a is the acceleration. This means that the net force on an object is equal to its mass multiplied by its acceleration.
3. How does Newton's 2nd Law relate to everyday life?
Newton's 2nd law can be observed in everyday life, for example, when pushing a shopping cart. The harder you push, the faster the shopping cart will accelerate. Similarly, a heavier shopping cart will be harder to push than a lighter one.
4. What is the difference between mass and weight in relation to Newton's 2nd Law?
Mass is the measure of the amount of matter in an object, while weight is the measure of the force of gravity acting on an object. In relation to Newton's 2nd law, mass is a constant factor that affects the object's acceleration, while weight may vary depending on the strength of gravity.
5. How does Newton's 2nd Law apply to objects in motion?
Newton's 2nd law applies to objects in motion by determining how the object's motion will change when a net force is applied to it. If the net force is greater than the object's inertia (resistance to change in motion), the object will accelerate in the direction of the net force. If the net force is equal to the object's inertia, the object will maintain constant velocity, and if the net force is less than the object's inertia, the object will decelerate or come to a stop.
  • Mechanics
  • Mechanics
  • Mechanics
