Newton's gravitational formula wrong?
The discussion revolves around the validity and universality of Newton's gravitational formula, particularly in the context of light and its interaction with gravity. Participants explore the implications of general relativity on Newtonian gravity, examining whether Newton's equation can be considered universal, especially for massless particles like light. The conversation includes theoretical considerations, historical context, and mathematical reasoning.
  • Some participants argue that Newton's gravitational formula is a good approximation but is superseded by general relativity, suggesting it is not universal.
  • Others propose that Newtonian gravity can predict the bending of light under certain assumptions, indicating that it is not entirely "wrong."
  • A participant mentions that light, despite having zero mass, is affected by gravity, questioning the applicability of Newton's equation to massless objects.
  • There is a discussion about the mathematical implications of applying Newton's law to massless particles, with some asserting that the equation requires mass to be non-zero for derivation.
  • Some participants emphasize that the acceleration due to gravity is independent of mass, which leads to the conclusion that gravitational effects should apply to massless particles as well.
  • Participants reference historical perspectives, noting that Newton anticipated light bending due to gravity, but acknowledge that Einstein's treatment is more accurate.
  • There are claims that both Newtonian gravity and general relativity have limitations and are not perfect, with discussions about the ongoing search for a unified theory.
Participants exhibit disagreement regarding the universality of Newton's gravitational formula, particularly in its application to massless particles. While some view it as a good approximation, others challenge its applicability and correctness in light of general relativity. The discussion remains unresolved with multiple competing views present.
Some claims rely on specific assumptions about the nature of mass and gravity, and there are unresolved mathematical steps regarding the application of Newton's laws to massless particles. The conversation reflects a range of interpretations and understandings of gravitational theory.
akshaya
Hi,
According to Newton, F= (GM¹M₂)/r²
Einstein proved that light bends around massive bodies, due to gravity. (because space bends around these bodies)
Mass of light = zero, but its being affected by gravity. So, is Newton's equation not universal?
No, Newtons gravity is most often a good approximation, but it is superseeded by general relativity.
It is not. As Orodruin says, it is a good approximation... but it would be a mistake to take the next step and say that it is "wrong".
I point people at this essay from time to time: http://chem.tufts.edu/AnswersInScience/RelativityofWrong.htm
In addition to what's said above, it should be pointed out that Newtonian gravitation does predict bending of light around massive bodies after making a some very reasonable assumptions. Basically, rather than being combined into the standard force law, you should think of Newtonian gravity as a field equation: ##\vec{E} = GM/r^2## along with a force law analogous to the electrostatic force, ##\vec{F} = m\vec{E}##. Now, despite not knowing how, exactly, such a gravitational field affects massless objects, it's fairly clear that if massless objects exist it must affect them. Just start with a massive object and apply these equations plus ##\vec{F}=ma## and deduce that it accelerates at a rate independent of its mass, ##\vec{a} = \vec{E}##. Now take the limit of the mass to zero and the acceleration stays the same. You can make the mass infinitesimally small and it will still accelerate at the same rate. It would be exceedingly strange if gravitational acceleration were discontinuous—zero for something massless and finitely small for anything arbitrarily close—so it's reasonable to deduce that the identification of acceleration with the gravitational field is completely general. Then by treating light as massless particles, you can figure out how much it deflects when passing by massive bodies. This was done around 1800 and generally accepted by the scientific community, well before Einstein and relativity.
It's commonly stated that, as Eddington tested, GR predicts light bends and Newtonian gravity predicts it does not. This is not true, or at least doesn't reflect the understanding of Newtonian gravity at the time. In fact, the prediction by GR is that light bends exactly twice as much as Newtonian gravity predicts. It's also now generally accepted that the accuracy of Eddington's experiment was insufficient to support his conclusion in favour of GR; however, since then we've done much more precise tests that have confirmed relativity's prediction over Newton's.
Well, E = GM/r^2 is applicable only IF the particle has mass, even if its infinitesimally small. Since light's mass is zero, it would not be possible to equate this:
>F= (GM¹M₂)/r²
>ma/m= GM/r²
m=0, so the LHS is not defined.
I guess the universal law of gravitation is not applicable to mass-less objects. (Then why is it called a law? haha) It's just a good approximation. And plus, if Newtonian equation already proved light bends due to gravity, I don't think Einstein would have needed to struggle to prove it.
If you think I'm not understanding something here, can you stress on that? Sorry, I'm just a 10 grader :)
You understand, do you not, that Einstein's theory is, at best, an approximation that will, more than likely, be replace by some other theory that is a better approximation.
akshaya said:
Hi,
You know, that Newton was also a smart guy. I've read somewhere he also expected that trajectories of light rays should be bent due to gravity of massive object. He considered light to be particles (lat. corpuscula) in such case. But treatment and calculation of the effect with Einstein equation is much more correct and accurate .
>F= (GM¹M₂)/r²
>ma/m= GM/r²
We had a thread on this:
https://www.physicsforums.com/threads/dividing-by-m-to-make-conclusions-for-m-0.770703/
Like all of physics.
Einstein's theory predicts a different amount of light bending, than Newtonian acceleration.
http://mathpages.com/rr/s8-09/8-09.htm
Do you know anything about calculus? I was using the concepts of "limit" and "continuity" which come from calculus. It's with those concepts that the notion of applying Newton's law of gravity to massless particles is justified.
Really? I had no idea. Interesting...
The observation that led Newton to his laws was that a = g, independent of mass. From that one can infer ma = mg. To then say that this fails when m = 0 doesn't follow. No calculus required.
This is incorrect. There is nothing about that equation that requires m to be non zero, particularly if it is taken as the starting point.
This is how physics is done since the beginning of human history, that is, if you have a theory that explains or fits for a wide set (but not everything) of phenomena you can call this theory or law universal though it really isnt. It just gives us right answers for most of what is happening but not for absoletuly everything that is happening out there.
Even general relativity isn't perfect (it is very good-but still not perfect-only for gravity) or quantum physics (very good-but still not perfect-for anything else except gravity). Unification of quantum physics and general relativity hm that's another story (but still not perfect hehe). And ofc don't forget dark matter or dark energy quantum physics or GR don't say much for those either.
How is it incorrect? To derive that equation, m needs to have a value. 1/0 is not defined.
You don't need to derive the acceleration law, you can take it as the starting point.
In fact, scientifically the force law (dynamics) was derived from the observed acceleration law (kinematics), not the other way around. In other words, you observe the fact that the acceleration is independent of the mass, and then you multiply that by mass to derive the force law.
However, even if you do derive it from the force law the derivation can still be valid under certain conditions. Specifically, if ##F=GMm/r^2=gm## holds for all m and if ##F=ma## holds for all m then ##a=g## as shown here:
https://www.physicsforums.com/threa...onclusions-for-m-0.770703/page-3#post-4852663
The key condition mathematically is the "for all m".
Apparently the mods thought my original post was too strong. Unfortunately, the point seems to have been missed.
There is no division by zero. Newton's starting point is a = g.
Physics is not about memorizing a bunch of equations. You need to understand the line of argument leading to these equations.
I have always wondered about this.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 29 ·
  • · Replies 27 ·
9K
