Newton's law of cooling problem: Differential Eq
The discussion revolves around solving Newton's Law of Cooling applied to a thermometer's temperature readings. Initially, at 1:00 PM, the thermometer reads 70°F outside in -10°F conditions, dropping to 26°F by 1:02 PM. After being brought indoors at 1:05 PM, the air temperature is 70°F. The calculated temperature at 1:09 PM is approximately 68.1°F, derived using the differential equation du/dt = -k(u - u_o) with k determined as 0.39925.
  • Understanding of Newton's Law of Cooling
  • Familiarity with differential equations
  • Knowledge of temperature conversion (Fahrenheit to Celsius)
  • Ability to integrate exponential functions
  • Study the derivation of Newton's Law of Cooling in detail
  • Learn about solving first-order linear differential equations
  • Explore the implications of temperature changes in thermodynamic systems
  • Investigate real-world applications of cooling laws in engineering
Students in physics or engineering, educators teaching thermodynamics, and anyone interested in practical applications of differential equations in temperature dynamics.
Edwardo_Elric
At 1:00 PM, a thermometer reading 70 degrees F is taken outside where the temperature is -10 degrees F (ten below zero). At 1:02PM, the reading is 26 degrees. At 1:05PM the thermometer is taken back indoors, where the air is at 70 degrees F. What is the temperature reading at 1:09PM?
\frac{du}{dt} = -k(u - u_o)
integrating we have
u - u_o = Ce^{-kt}
u is the temperature reading
u_o is the temperature of the atmosphere
solutions by sentences:
*"At 1:00 PM, a thermometer reading 70 degrees F is taken outside where the temperature is -10 degrees F (ten below zero)":
at t = 0 , u = 70
and u_o = 10
70 - (-10) = Ce^{-k(0)}
C = 80
Now we already know the constant
*"At 1:02PM, the reading is 26 degrees":
at t = 2; u = 26
26 - (-10) = 80e^{-k(2)}
k = 0.39925
my problem is that i don't understand when it is put indoors
*"At 1:05PM the thermometer is taken back indoors, where the air is at 70 degrees F":
the constant of proportionality is the same
(u - 70) = Ce^{0.39925t} <<< this might be the equation
...and i don't understand the problem anymore
the answer to this problem is 56 degrees Farenheit
integrating we have
u - u_o = Ce^{-kt}
at t = 0 , u = 70
and u_o = 10
C = 80
at t = 2; u = 26
k = 0.39925
You have calculated u(t) as long as the thermometer is outside. What will the temperature of the thermometer be when t= 5 (at 10:05)?
Now you have a new problem to do: u is now whatever you got for the temperature at 10:05 and u0= 75. Fortunately k is exactly the same as before (it depends only on the thermometer) so you don't need to calculate that again.
for the time at exactly before 5 minutes i used the equation:
u - (-10) = 80e^{-0.39925(5)}
so
u = 0.8675 degrees
problem:
so here it is now indoors and the air temperature is 70
for the time exactly after 5 minutes:
when t = 0, u = 0.8675 degrees;
(0.8675-70) = C(e^{0})
so
C = -69.1325
"What is the temperature reading at 1:09PM?"
t = 9min, u = ?
(u - 70) = -69.1325e^{-0.39925(9)}
u = 68.098 degrees
my answer seems to be wrong... can you please verify ?
15K
20K
11K
11K
15K
