Newton's laws and incline surfaces
The discussion centers on solving a physics problem involving a box moving up a 20-degree incline with an initial velocity of 5 m/s. Participants struggle with calculating the correct acceleration and distance traveled before the box comes to rest. The correct approach involves using the gravitational component acting down the incline, specifically applying g sin(20) for acceleration. Several calculations are attempted, with errors identified in the use of trigonometric functions and the final distance formula. Ultimately, the correct method is emphasized, leading to a more accurate solution for the distance traveled.
naada
A box is given an initial velocity of 5m/s up a smooth 20 incline surface . The distance the box travel before coming to rest is?
I can't solve it correctly , I can't get the idea of this question
x= ?
vi=5
v=0
a=?
F = ma
mg cos ? = a
tan-1 20 = 87.14
180 = 90 + 87.14 + ?
?= 180 -90-87.14
?=2.9
(mg cos 2.9 = ma ) /m
g cos 2.9 = a
a= 28.03
x = 25 /( 28.03 )2
x= 0.45 m
My answer is so wrong !
But i can't figure out how to solve this problem
Presumably a 20 degree incline?
F = ma
mg cos ? = a
What's the component of the weight acting down the incline?
tan-1 20 = 87.14
?= 180 -90-87.14
?=2.9
Not sure what you're doing here. I presume that the angle is given as 20 degrees.
g cos 2.9 = a
a= 28.03
You have the wrong angle (and trig function).
x = 25 /( 28.03 )2
x= 0.45 m
Sanity check: The acceleration due to gravity is only 9.8 m/s^2, so how can the acceleration parallel to the incline be greater than that?
Find the correct acceleration and that kinematic equation will work.
Read this to learn how to handle inclined planes: http://www.physicsclassroom.com/Class/vectors/u3l3e.cfm"
the question didn't mention the word "degree" or " ْ "
it's exactly as I wrote it .
So I toke 20 as the slop
x=? vi=5 vf=0 a=?
F = ma
(m g cos20 = m a) / m
9.8 cos20 = a
a=9.21
x=25/(2a)
x=25/(18.42)
x=1.37 m
Which is also wrong
180 = 90+20+?
180 -90-20=70ْ
F= m a
(m g cos 70 = m a)/m
9.8 cos 70 = a
a=3.35
x=25/(2a)
x=25/(2*3.35)
x=3.37 m
I think this one is the right one,but not sure.
thanks for the link was so useful
I would take it to mean a 20 degree angle to the horizontal.
x=? vi=5 vf=0 a=?
F = ma
9.8 cos20 = a
a=9.21
x=25/(2a)
x=25/(18.42)
x=1.37 m
Which is also wrong
It's wrong because you took cos20, which is the component perpendicular to the incline. You need the parallel component.
180 = 90+20+?
180 -90-20=70ْ
F= m a
9.8 cos 70 = a
a=3.35
x=25/(2a)
x=25/(2*3.35)
x=3.37 m
This time you used the correct acceleration (which is g sin20), but you made a small error in your final calculation--probably a typo. (Redo the very last step.)
Other than that minor problem, you got it right.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
