Newton's Rings using refractive index of water
The discussion focuses on the observation of faint Newton's Rings when using distilled water as the medium instead of air. Participants note that replacing air with water decreases the intensity of reflected light due to a smaller difference in refractive indices, resulting in less light being reflected. The setup involves a plano-convex lens and a glass slide positioned at a 45-degree angle, illuminated by a sodium lamp. It is explained that the slower light speed in water effectively increases the gap between the surfaces, leading to more closely spaced rings that are harder to discern. Overall, the faintness of the rings is attributed to these optical effects related to the refractive index change.
emmalou
Hi
I am currently looking at Newtons Rings, i have changed my refractive index to water (distilled), i have found the rings and they seem to be as aspected except they are extremely faint barely readable infact would anyone know a cause or soulation to this?
Science news on Phys.org
It's hard to say without more detail of your experiment.
What index did you changed to water? Or of what?
Did you put water between the curved surface and the plane surface?
i changed the index from air to water to see the affects, yes i did byt it between the curved surface and the plane surface.
The lense i am using is a planeo-convex lens and i have my glass slide at 45 degrees my lamp is also a sodium!
this is a picture of my set up
Well, by replacing air with water you decrease the intensity of the reflected light at both interfaces.
The reflection coefficient depends on the difference between the indices. If you reduce the difference more light will just get through, without being reflected.
What would you expect if you replace the water with glass of the same index as the lens and slide (without any air at the interface)?
As the light travels slower in the water, it is equivalent to having a bigger gap, and so the rings will be more closely spaced and harder to see.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
