Troubleshooting Nichrome Wire for Cigarette Lighter
  • Thread starter Thread starter JamesIzzard
    Nichrome Wire
The discussion revolves around troubleshooting the use of nichrome wire as a heating element for a cigarette lighter. The user experiences rapid heating followed by cooling when connected to a 9V battery, indicating that the battery is insufficient for the required current. It is noted that a standard 9V battery can only provide about 50mA, which is far too low for the application, as the nichrome wire needs approximately 1.5 amps to reach the desired temperature. The conversation highlights the importance of understanding the relationship between voltage, current, and resistance in heating applications. Overall, a more powerful power source is necessary to achieve the desired heating effect.
JamesIzzard
Hello all...
I have been having some trouble with some nickel/chromium resistance wire I have brought to act as a heating element, it is 0.375mm dia. and I am using 100mm lengths. I had originally intended to heat it up with a standard 9V battery, but it is behaving strangely when I connect it to the +ive & -ive terminals. It seems to heat up very quickly at first, as it should, and then stop heating and cool down after the first few seconds. It is definitely not flattening the battery, becuase if I wait a while and try again, the same thing happens.
Is this something to do with it shorting the battery, and is it even possible to heat wire like this with a 9V battery, ideally so it glows red. (I am trying to make a cigarrette lighter)
Apologies if this is a stupid question, electricity really is not my strong point :)
Welcome to PF.
When you draw too much current from a battery it can create a depletion zone and the battery will act like it is dead.
Disconnected, new carriers can migrate to the chemical interface and the battery will recover.
In general, this greatly shortens the usable life of the battery.
A standard 9V battery is far to small for your application.
The max output is about 50ma to achieve rated lifetime.
Ahh Ok right, that sounds like exactly what has been happening.
In terms of heat output of the nichrome wire then, is the current or the voltage more relevant, and why, and also I don't know where to start looking for equations to help me work out the nescessary voltages/amps needed to heat the wire to the nescessary temperature, could anybody point me in the right direction.
Sorry about asking for what I am sure is basic knowledge, I am more in the field of force mechanics, and am pretty new to electricity.
E=IR.
Or Voltage = Current times Resistance.
As you can see from that, all the values are related.
Power dissipated in the wire heats it.
P=EI.
According to this table: http://www.wiretron.com/nicrdat.html
Your wire requires almost 1.5 amps to reach 400 F.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
