Noises on Phone line when touching appliances
  • Thread starter Thread starter Homer Simpson
    Line
A noisy phone line in the kitchen is likely caused by interference from light dimmers, which generate electromagnetic waves due to their sharp turn-on edges. When touching grounded appliances, a click is heard on the line due to a high current spike that brings the body to ground potential, causing abrupt changes in current that can broadcast noise. The phone's plastic casing does not prevent this interference, as it can pick up a range of frequencies from unshielded circuits. Human body capacitance and self-inductance also contribute to the noise, as the current oscillates before settling. Addressing the issue may involve improving circuit shielding or using devices that minimize electromagnetic interference.
Homer Simpson
Not so much an engineering question, but electrical.
I've got a noisy phone line in my kitchen and not sure what's going on... more curious about the electrical theory than anything else.
-when operating either of 2 light dimmers in the area, loud hum on phone line.
-when first touching any grounded appliance, hear a click on the line as if I am discharging or something.
-the phone is plastic all around so it seems bizarre to me that it would make any noise when touching appliances.
Any thoughts?
Thanks.
Light dimmers are notoriously noisy. 120 times a second there's a sharp turn-on edge, that splatters electromagnetic waves over the spectrum. Turned all the way on, you should notice that the noise diminishes.
When you touch ground a high current spike occurs that takes your body to ground potential. The abrupt change in current (from zero, before discharge) is what causes the broadcasting. There are a lot of frequencies represented, so a good chance of picking it up in a circuit not shielded or filtered well enough. Apparently, it doesn't require a noticable arc to receive it, in your phone.
People are modeled at about 50 pF capacitance. There's also self inductance, even a straight conductor. The current actually oscillates a bit before going to zero, if the resistance isn't too high. This part of the signal has a narrower band, than the sharp, arc-over start.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
