Is the Magnetic Field Non-Conservative in Nature?
  • Thread starter Thread starter i_island0
The discussion centers on whether the magnetic field is conservative or non-conservative. It highlights that while magnetic fields form closed loops, they do no work on charged particles, leading to the conclusion that they are conservative forces. The work done by magnetic forces is zero since the force is always perpendicular to the displacement of the charged particle. Additionally, while a magnetic dipole can have potential energy in a magnetic field, the work done on it along different paths remains zero, reinforcing the conservative nature of the magnetic field. The conversation concludes that despite some complexities, magnetic fields are generally considered conservative, especially in the absence of currents.
i_island0
magnetic field forms closed loop always. So, it should be called a non-conservative force.
But if a charged particle enters a magnetic field, it would move in a straight line or circular path or an helical path. In all the three cases, the magnetic field won't do any work on the charged particle. So, is it worth talking about the non-conservative in nature of magnetic field.
A non-conservative force is a force which does zero work in a closed loop in simple terms means that, if an object under a force is moved a path AB and the work done be 'W', then if the object is moved along the path BA keeping all under conditions same, then the work done by the force will be '-W'. Mathematically, you can say that:
<br /> \int_A^{B} Fdr + \int_B^{A} Fdr = 0<br />
for a conservative force 'F'. The 'closed loop' that we talk about isn't the loop made by the field.. but rather the path moved by an object under that force.
The direction of a field, in a sense is arbitary. The direction of Magnetic field is defined as 'the direction along the component of velocity on which the force applied does not depend upon'.
The work turns out to be 0 since, the Force is always perpendicular to the displacement. Take the example when the charge makes a circle. The Force direction is radial whereas the displacement is tangential and hence the cross product F.dr = 0.
However, a magnetic field does work on a magnetic dipole. A magnetic dipole in a magnetic field has an associated potential energy. Also, if you move a magnetic dipole along paths AB and BA in a magnetic field, the work done on them is 0. Magnetic force is a conservative force.
hey, can you put some more light on this. I read somewhere that magnetic field is non-conservative field.
Can it be proven mathematically that magnetic field [uniform or non-uniform] is a conservative field always.
Easily... Work is the path integral of force dotted with velocity. Magnetic force is given by the cross product of velocity and magnetic field. Therefore Magnetic force is perpendicular to velocity. Therefore Magnetic force dotted with velocity is 0. Therefore work is 0. (Here I am assuming conservative <-> does no work in a closed path (or in this case any path))
ok fine.. but the general definition of a non-conservative field lines is that they form closed loop.
So, what would shall we conclude, in general, about the nature of magnetic field. Conservative or non-conservative.
The answer is already posted above. Maybe you should read into this a bit more?
Again, a field is conservative if the work done around an arbitrary curve in the force field is zero throughout the closed path C.
In this case the magnetic force is perpendicular to the velocity throughout the integral C and this results in a dot product yielding zero.
The point is if the closed loop integral's work is zero, then the field is conservative.
You can read a summary of conservative forces here: http://en.wikipedia.org/wiki/Conservative_force
I think this excerpt may be of value to you:
The gravitational force, spring force, magnetic force and electric force (at least in a time-independent magnetic field, see Faraday's law of induction for details) are examples of conservative forces, while friction and air drag are classical examples of non-conservative forces (the energy is transferred to the air as heat and cannot be retrieved).
The magnetic field is a conservative vector field since one may write it as the gradient of a scalar field, the potential field,
\underline{B} = \nabla A\left(\underline{p}\right)
Therefore by definition the magnetic field is conservative.
thx... i got few more questions in this regard. IF you can tell me if I am conceptually correct.
Electric field produced by stationary charges - conservative in nature
Induced electric field - non-conservative nature
Uniform Magnetic field (forming closed loops) - conservative in nature
Non- Uniform Magnetic field (forming closed loops) - conservative in nature
magnetic field Changing with time- ? Shall i call it conservative or since its inducing and electric field.. so rather call it non-conservative.
Correct:approve:
A time-varying magnetic field is still conservative (since it still satisfies the condition I detailed previously). However, as you correctly say, the electric field induced by a time-varying magnetic field is non-conservative.
thats great.. thx.. i got it this time
Erm, I don't quite know about this.
Suppose \vec{B} = \nabla{A}
Then
\nabla\times\vec{B} = \nabla\times\nabla{A}
Now the curl of a gradient is always 0, so
\nabla\times\vec{B} = 0 = \mu_0\vec{J}
So this is only true in a current free region. Thus I would say the magnetic field is only conservative in the sense that it does no work in a closed path, but not in the sense that there exists a scalar potential A such that B = grad A. In standard vector calculus you learn that these statements are equivalent, but that assumes the vector functions depend only on position, and not on path, as does the magnetic force.
You are of course correct nick, the scalar potential is not defined where there exists a non-zero current density. One can allow sources in the magnetic potential, provided that the sources lie on the discontinuities of the potential.
I should also add however, that we can always write the magnetic field as the curl of the magnetic vector potential, that is we can always write,
\underline{B} = \text{curl}\left(\underline{A}\right)
So, if I make a unit magnetic monopole move in a closed path around a current carrying wire, there is some non-zero work done. Then in that case, can we say that magnetic field is non-conservative in nature.??
