kleinwolf said:
the problem with this, is that with the operator A=diag(1,1,-1) and x=1/sqrt(2)(1,0,1) is that there are two kind of unitary operations :
-1) it "collapses" (I know you don't like that word) to the eigenvector corresp. to -1, but the measurement still is ideal
+1)
a) it collapses to y=(1,0,0) and is ideal (at least I suppose from your previous messages)
b) it collapses to y=(cos(phi),sin(phi),0) and there exists phi for which it is not ideal...
How do you make the difference between the two unitary operations that determine if the measurement is ideal or not ?
Well, consider the three state system of your example, with states |1>,
|2> and |3> (so (1,0,0) ; (0,1,0) and (0,0,1) in the basis you use).
Let us consider the two pointer states |psi1> and |psi2> corresponding to the two outcomes of the measurement. Let us call |psi0> the state of the measurement apparatus before the measurement.
If my measurement apparatus corresponds to U1, with U1:
|psi0> |1> ==> |psi1> |1>
|psi0> |2> ==> |psi1> |2>
|psi0> |3> ==> |psi2> |3>
then the measurement apparatus will give you an ideal measurement.
However, the physics of my measurement apparatus could be different, and it could correspond to an operator U2:
|psi0> |1> ==> |psi1> (cos th |1> + sin th |2>)
|psi0> |2> ==> |psi1> (-sin th |1> + cos th |2>)
That would be your other case. In both cases, the measurement apparatus corresponds to the hermitean operator you cited, but the second kind of apparatus is not an "ideal measurement" apparatus.
The reason is that the hermitean operator determines not uniquely the unitary evolution of the measurement apparatus, unless you ALSO specify that it is "ideal". The reason is that the hermitean operator is made up of 2 things:
A) The projection operators on the eigenspaces that correspond to the POINTER states ; in this case:
space 1 corresponds to the pointer state |psi1> which is reached from states |1> and |2>, so the projector projects upon the space spanned by |1> and |2> ==> P1
space 2 corresponds to the pointer state |psi2> which is reached from state |3>, so the projector P2 projects onto the space generated by P2.
B) the "measurement values" we assign to these pointer states (the values on the display), say m1 and m2.
The hermitean operator of the measurement is then simply:
m1 P1 + m2 P2
Clearly, what happens to the state of the system is not included in that description, and both U1 and U2 give rise to the same hermitean operator.
But if on top of that you require a measurement to be *ideal* so that the corresponding state that goes with the pointer state |psi1> is the projector P1 applied to the state of the system, THEN the unitary operator that goes with it IS uniquely determined from the Hermitean operator.
cheers,
Patrick.
