Non equilibrium thermodynamics: T as a function of time
When two separate gas systems with different temperatures, pressures, and volumes are combined, their initial inhomogeneous distribution requires careful analysis. The Navier–Stokes equations are suggested as a foundational approach for simulating the system's behavior over time. Additionally, incorporating the differential energy balance equation is essential for accounting for heat conduction within the combined system. The discussion highlights the complexity of deriving an average temperature equation as a function of time. Overall, a combination of simulation and analytical methods will be necessary for accurate modeling.
pterodox
Hi.
Let's say we have two separate systems (containing gases), each with their own temperature, pressure and volume. Then these systems are brought together, with no walls in between. Of course, one might consider they are now technically the same system, but the distribution of pressure and temperature is inhomogeneous for a while.
Is there an equation that I could use to calculate the average temperature of any volume inside this space as a function of time?
Thanks.
Science news on Phys.org
You can simulate the system, sure. The Navier–Stokes equations are probably a good start.
Analytic equations might give reasonable approximations for some setups.
Likes pterodox
In addition to what mfb said, you would also have to include the differential energy balance equation to include heat conduction within the system.
Likes pterodox
Thank you both! I'll look into those. This might be a bit tougher than I initially expected.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
