Non intersecting phase space trajectories
In an autonomous system of equations, phase space trajectories do not intersect, which can be proven mathematically. If two trajectories were to intersect, it would imply that the system could have two different future states from the same initial condition, violating the uniqueness of solutions. The physical significance of non-intersecting trajectories indicates that the system's evolution is deterministic and predictable. If trajectories were to intersect, it could lead to chaotic behavior or multiple outcomes from a single state, complicating the system's dynamics. Thus, the non-intersection of trajectories is crucial for maintaining the integrity of the system's predictive nature.
geet89
The phase space trajectories of an autonomous system of equations don't intersect.
Can this be proved mathematically.
Also what is the physical significance of this statement. What happens if they intersect?
Hint: What would happen if you had two trajectories departing from the same point (which is another way of saying that there are intersecting trajectories)?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
