Why Is ZnO Conductivity Non-Linear?
ZnO exhibits non-linear conductivity primarily due to its n-type semiconductor properties, which facilitate easy transitions to the conduction band. As temperature increases, conductivity rises until a saturation point is reached, where excess electrons lead to energy loss through heat rather than electrical conduction. This behavior is particularly useful in surge arresters, as the material's resistance increases with temperature, protecting circuits from excessive current. The phenomenon is linked to grain boundaries, although the exact mechanisms remain a topic of ongoing discussion. Understanding these dynamics is crucial for applications involving ZnO in electronic devices.
eric336
I want to understand the conductivity of ZnO. I know it is non-linear (that's why it is used in surge arrester to begin with), but can anyone enlighten me on why it is non-linear? Is it the function of electric field, current, or anything? I'd appreciate if you can provide the expression of conductivity.
ZnO is a semiconductor material that naturally is n-type without doping. Thus it will have a good conductivity because it allows easy transitions to the conduction band (what it means to be n-type).
These slides go over it
http://www.iwe.kit.edu/plainhtml/lehre/mad/pdf/Nonlinear%20Resistors.pdf
If you look at the chart in here of current generation you can see how this works.
Basically it increases as the temperature increases to a point because the heat vibrations allow additional electrons to make the bandgap jump; however, eventually you reach a point where you keep pumping electrons into conductive band and it gets crowded so the conflicting movement causes a net loss of energy (the conflicting movement results in more heat loss than electrical conduction). So for a surge protector you can see how it would be valuable that when it gets oversaturated it heats up thus lowering the conductivity ... which if the current doesn't go down causes more heat ... and you see the pattern. More resistance = more heat which protects the circuit by increasing it's resistance when it heats up / when excessive current runs through it.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
