B Gravity in Hollow Shell: Nonadditivity and Relativistic Self-Interaction
  • B
  • Thread starter Thread starter snorkack
    Gravity Shell
snorkack
Classical gravity is additive.
Therefore classical gravity obeys Gauss´ law. One result is absence of gravity in any hollow, spherically symmetric shell.
In general relativity, gravity is not additive.
Simple example is a black hole.
The gravity of a classical point mass diverges to infinity at zero distance, and the field flux is conserved. The gravity of a black hole diverges to infinity at a nonzero distance, and the field flux also diverges to infinity.
But the gravity of any mass distribution is nonadditive and the flux increases inwards.
Now, how does the relativistic self-interaction of gravity field work inside a hollow shell (that is not massive enough to be a black hole)? Does the field still cancel inside?
Yes. Birkhoff's theorem says that the only spherically symmetric vacuum solution to Einstein's field equations is Schwarzschild's. And that only depends on the enclosed mass.
Likes Matterwave
If the hollow shell is not moving then Ibix's answer applies - Birkhoff's theorem says the interior metric is Minkowski. If the hollow shell is rotating though you will get a Lense-Thirring effect (frame dragging). That's the level (for this scenario) at which GR would depart from Newtonian predictions.
Likes Ibix
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
