Nonconservative gradients (not an oxymoron)
  • Level: Graduate
  • Thread starter Thread starter okkvlt
3 replies · 2K views
okkvlt
fx,fy=-y,x
curl(fx,fy)=2
its counterclockwise so the gradient is pointing ccw.
the gradient is the direction of max increase, so
then the surface z=f[x,y] whose gradient is -y,x is a spiral/screw whose z position goes up forever as x and y are traced out counterclockwise
so, a nonconservative field IS a gradient of a surface.
why was i lied to?
I think you're going to need to write this out clearer. How can the curl of a vector be a number? How can the gradient of a three variable equation be a two dimensional vector?
okkvlt said:
fx,fy=-y,x
curl(fx,fy)=2
why was i lied to?
Hello there! Okay, let's take it step by step and yes, please do be a little clearer so we can understand exactly what you're saying. I think what you're saying is that you're trying to find the surface whose gradient at each point is (-y,x,0)? How did you make these out to be spirals?
So let's see, you've got the vector field:
[tex]\vec{V} = (-y, x, 0)[/tex]
Ye? And you've calculated its curl, which is:
[tex]Curl \vec{V} = (0,0,2)[/tex]
so the field is 'rotating' counterclockwise viewed from above (the positive z axis). The curl of your vector field is constant in all of space, and non-zero. Because it is non-zero means that your vector field [tex]\vec{V} = (-y, x, 0)[/tex] cannot be a gradient, in other words, there is no scalar field whose gradient is [tex]\vec{V}[/tex]. That is, there are no surfaces whose gradient at each point is (-y, x, 0). But! this does not mean that there are no surfaces which are orthogonal at each point to [tex]\vec{V}[/tex]. In fact, in your case, these surfaces DO exist, because the vector field [tex]\vec{V}[/tex] is normal to its curl.
Just to help visualize, here is the curl of your vector field V, as viewed from above:
http://img31.imageshack.us/img31/4605/curl.gif
