Mmmm
- 63
Let u(x,t) be the solution of the following initial value problem for the nonhomogeneous wave equation,
[tex]u_{x_1x_1}+u_{x_2x_2}+u_{x_3x_3}-u_{tt}=f(x_1,x_2,x_3,t)[/tex]
[tex]u(x,0)=0[/tex] and [tex]u_t(x,0)=0[/tex]
[tex]x\in\Re^3 , t>0[/tex]
Use Duhamel's Principle and Kirchoff's formula to show that
[tex]u(x,t)=-\frac{1}{4\pi}\int_{\overline{B}(x,t)}\frac{f(x',t-r)}{r}dx'_1dx'_2dx'_3[/tex]
where
[tex]r=\left|x-x'\right|=[(x_1-x'_1)^2+(x_2-x'_2)^2+(x_3-x'_3)^2]^\frac{1}{2}[/tex]
and [tex]\overline{B}(x,t)[/itex] is the ball in [itex]\Re^3[/itex] with center at x and radius t.
Duhamel's Principle
Let [itex]v(x,t;\tau)[/itex] be the solution of the associated (to the above initial value problem) "pulse problem"
[tex]v_{x_1x_1}+v_{x_2x_2}+v_{x_3x_3}-v_{tt}=0[/tex]
[tex]v(x,\tau;\tau)=0[/tex] and [tex]v_t(x,\tau;\tau)=-f(x,\tau)[/tex]
[tex]x\in\Re^3 , t>\tau[/tex]
then
[tex]u(x,t)=\int^t_0v(x,t;\tau)d\tau[/tex]
Kirchoff's Formula
Suppose [itex]p\in C^k(\Re^3)[/itex] where k is any integer [itex]\geq[/itex]2 Then the solution of
[tex]u_{x_1x_1}+u_{x_2x_2}+u_{x_3x_3}-u_{tt}=0[/tex]
[tex]u(x,0)=0[/tex] and [tex]u_t(x,0)=p(x)[/tex]
is given by
[tex]\frac{1}{4\pi t}\int_{S(x,t)}p(x')d\sigma_t[/tex]
where S(x,t) is the surface of the sphere with radius t and centre at the point x. [itex]d\sigma_t[/itex] is the element of surface on S and x' is the variable point of integration.
I should split this into two parts, one for each formula.
first I need to use Kirchoff's formula to find v and then Duhamel's principle to find u.
The problem with using Kirchoff is that the initial conditions are given at t=0 whereas our initial conditions for v are at [itex]t=\tau[/itex]
So a transformation into kirchhoffs formula to give the required initial conditions, [itex]t'=t-\tau[/itex]
so
becomes
[tex]v(x,0;\tau)=?[/tex] and [tex]v_t(x,0;\tau)=-f(x,?)[/tex]
which doesn't give me anything because of that parameter in v. The t value and the parameter must be equal to give a known value.
Can anyone give me a clue as to how to get Kirchoff's formula to work with this? Or am I going in completely the wrong direction?
I'm sure that this is only the first of many sticking points in this question but I thought I'd ask one question at a time...:)
