Normalization of 4-velocity in general relativity
32 replies · 16K views
It seems that you are treating [itex]R[/itex] as a constant, but I still don't see how to use
jmlaniel said:
[tex]\bar{t} = t \sqrt{1-R_s/R}[/tex]
[tex]\bar{r} = \frac{r}{\sqrt{1-R_s/R}}[/tex]
to go from
jmlaniel said:
Here is the "standard" Schawzschild metric :
[tex]ds^2 = -\left( 1-R_s/r \right) dt^2 + \left( 1-R_s/r \right)^{-1} dr^2 + r^2 d\Omega^2[/tex]
to
jmlaniel said:
then I get the following metric :
[tex]ds^2 = -\frac{(1-R_s/\bar{r})}{(1-R_s/R)} d\bar{t}^2 + \frac{(1-R_s/R)}{(1-R_s/\bar{r})}d\bar{r}^2 + \bar{r}^2 (1-R_s/R) d\Omega^2[/tex]
For example, using
[tex]dt = \frac{d\bar{t}}{\sqrt{1-R_s/R}}[/tex]
[tex]r = \bar{r} \sqrt{1-R_s/R}[/tex]
in the first term of the standard Schwarzschild metric gives
[tex]\left( 1-R_s/r \right) dt^2 = \frac{\left( 1 - \frac{R_s}{\bar{r} \sqrt{1-R_s/R}} \right)}{1-R_s/R} d\bar{t}^2 .[/tex]
jmlaniel said:
Here are my new variables :
But, like George, I don't understand how this is obtained by the transformation proposed above. Nor do I get the meaning of [tex]R[/tex] in your equations. It is most likely that a factor [tex](\sqrt{1-R_s/R}})[/tex] is missing in the denominator of [tex]R/\bar{r}[/tex] from the time component of the metric.
AB
I have to agree with George and Altabeh... I did not see the effect of the new r in the metric factor. My solution is entirely wrong :frown: But thanks a lot for pointing it out!
I have tried for the last hour to find a way to fix this and I am unable to do so. I will have to conlude that kev metric is suspicious... Unless anybody can find a way to justify this metric, I will have to say that it is imposisble to get from the standard Schwarzschild metric with a change of variable.
I really tried to accept this metric, but I can figure it out.
