How Much Ballast is Needed for a Scale Model Sailboat to Float Properly?
In summary: But that is the mass you need to make it "float like the real thing". "Ballasting" usually means adding weight to make it sink to a certain depth. To make it float and only float, you would need a little more weight than that. For example, if you added 1/1000 of the mass of the model, it would float with the deck at the same level as the actual sailboat. 0.38125 kg/1000= 0.00038125 kg= 0.38125 grams.In summary, to make the model sailboat float like the real thing, you would need to add a mass of 0.38125 kg or 0.
sonya
23
ok...
u have built an exact replica of ur favorite sailboat on a scale of 1 to 20. u know that the boat weighs 3050 kg. to wat total weight, in grams, would u have 2 ballast the model so it floats in water like the real thing?
i thot it would just b 3050/x = 20/1
then x = 152.5 kg
but...thats not the rite answer...as per usual...
ne1 want to help me get started on this 1?
Although you didn't say, I would conclude that your "Scale of 1 to 20" is a LINEAR scale. That is, the model is 1/20 as long as the original sailboat. Since the width of the model would also be 1/20 the width of the actual sailboat, the AREA of the deck of the model, for example, would be (1/20)(1/20)= 1/400 of area of the deck of the actual sailboat.
Since volume is "length times width time height", that is, 3 lengths multiplied together (hence "cubic feet" or "cubic meters" to measure volume), the volume of the model sailboat would be (1/20)(1/20)(1/20)= 1/8000 of the volume of the actual sailboat.
Assuming that your model is made of the same material as the actual sailboat (and so has the same density) you would need
1/8000 of the mass: 3050/x= 8000/1 so x= 3050/8000= 0.38125 kg.
Hi there, it seems like you are trying to calculate the weight of ballast needed for your model sailboat to float like the real thing. This is a physics problem, not a calculus problem. Calculus is a branch of mathematics that deals with rates of change and is not applicable in this situation. It might be more helpful to approach this problem using principles of buoyancy and density. The weight of the ballast needed will depend on the density of the material used and the volume of the model sailboat. You can start by calculating the volume of the model sailboat and then using the density of the ballast material to determine the weight needed for it to float. I hope this helps!
Related to How Much Ballast is Needed for a Scale Model Sailboat to Float Properly?
1. What is the difference between physics and calculus?
Physics is the branch of science that deals with the study of matter, energy, and their interactions. It involves understanding the fundamental laws and principles that govern the natural world. Calculus, on the other hand, is a branch of mathematics that deals with the study of change and motion. It is a powerful tool used in physics to describe and analyze motion and change in physical systems.
2. How does physics use calculus?
Physics uses calculus to describe and analyze physical phenomena, such as motion, forces, and energy. Calculus provides the necessary mathematical tools to model and solve complex physical systems, making it a fundamental tool in the field of physics.
3. What are some common applications of physics that use calculus?
Physics has numerous applications that use calculus, including mechanics, thermodynamics, electromagnetism, and quantum mechanics. Some examples include designing and building bridges and buildings, developing new technologies like computers and smartphones, and understanding the behavior of particles at the microscopic level.
4. Can physics be understood without knowledge of calculus?
While some basic principles of physics can be understood without calculus, a deeper understanding of the subject requires knowledge of calculus. Many physical phenomena can only be accurately described and predicted using calculus, making it an essential tool for physicists.
5. Is it possible to learn calculus without studying physics?
Yes, it is possible to learn calculus without studying physics. However, many concepts in calculus are heavily used in physics, so having a basic understanding of physics can help in learning and understanding calculus. Additionally, studying calculus can also provide a deeper understanding of the underlying principles and concepts in physics.
