Notation for Maps between Topological Spaces
Rasalhague
I'm used to the notation f : X --> Y for a map, where X and Y are sets. I recently came across this notation for a map between topological spaces, where the second item of each pair is a topology on the first:
f : (X,{t}a) --> (Y,{tb})
Is the notation to be read "f maps each element of X to an element of Y, and f also maps each element, of {t}a to an element of {tb}? (Presumably the domain and codomain aren't to be understood as in the nested sets definition of a tuple.)
Source: Fecko: Differential Geometry and Lie Groups for Physicists.
The notation is to be read "f is a map from the topological space (X,{t}a) to the topological space (Y,{tb})".
What it means to be such a map depends on context. The standard meaning is that it is a map of the underlying sets that has the property of being continuous.
Thanks Hurkyl. The example was indeed about continuous maps.
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
Thread 'Detail of Diagonalization Lemma'
The following is more or less taken from page 6 of C. Smorynski's "Self-Reference and Modal Logic". (Springer, 1985) (I couldn't get raised brackets to indicate codification (Gödel numbering), so I use a box. The overline is assigning a name. The detail I would like clarification on is in the second step in the last line, where we have an m-overlined, and we substitute the expression for m. Are we saying that the name of a coded term is the same as the coded term? Thanks in advance.
