Nth Derivative of an Even Function
In summary, the given function is even and the derivative of an even function is also even, so the nth derivative of the given function will be even for any even integer n. Since 0 is an even integer, the nth derivative of the given function evaluated at x = 0 will be 0.
FeDeX_LaTeX
Let ##f(x) = \frac{\sin x}{b + \cos(ax)}##. Show that the nth derivative ##f^{(n)}(0) = 0## if n is an even integer.
Leibniz's generalised product rule:
##(f \cdot g)^{(n)} = \sum_{k = 0}^{n} \binom{n}{k} f^{(k)}g^{(n-k)}##
I'm letting ##f(x) = \sin x## and ##g(x) = \frac{1}{b + \cos(ax)}## then applying Leibniz's rule. Clearly, the terms of the series k = 0, k = 2, ... (every even k) are all 0 when x = 0, since they all contain an even derivative of sin (which gives us sin again). But what do I do about the derivatives of g(x)? Is this the right approach?
Odd functions of x have only odd powers of x in their Taylor-McLaurin series, so...
So you're saying I let ##\frac{1}{b + \cos(ax)} = a_0 + a_{1}x^2 + a_{2}x^4 + ... ##?
There is a much, much easier way. Just answer the following three questions.
1. The given function is (a) odd; (b) even; (c) neither.
2. The derivative of an even function is (a) even; (b) odd; (c) neither.
3. The derivative of an odd function is (a) even; (b) odd; (c) neither,
1. What is the Nth derivative of a function?
The Nth derivative of a function is the derivative of the derivative of the function, repeated N times. It represents the rate of change of the rate of change of the function.
2. How is the Nth derivative of a function calculated?
The Nth derivative of a function can be calculated using the power rule, product rule, quotient rule, or chain rule. These rules are applied repeatedly N times to find the derivative at each stage.
3. What is the significance of the Nth derivative in mathematics and science?
The Nth derivative has many applications in mathematics and science, including optimization, curve fitting, and solving differential equations. It also helps to understand the behavior and characteristics of functions.
4. Can the Nth derivative of a function be negative?
Yes, the Nth derivative of a function can be negative. This indicates that the function is decreasing at a certain rate. A negative Nth derivative can also represent concavity, where the function curves downward.
5. How does the Nth derivative of a function relate to its graph?
The Nth derivative of a function can provide information about the shape and behavior of its graph. For example, a positive Nth derivative indicates an increasing function, while a negative Nth derivative indicates a decreasing function. The Nth derivative can also help identify points of inflection and the overall curvature of the graph.
