Number of Galaxies: Is It Infinite?
  • Thread starter meteor
  • Tags
    Galaxies
In summary, the conversation discusses the idea of the universe being infinite in size and the possibility of an infinite number of galaxies existing. One member poses the question of whether this is possible, and another provides their reasoning that it cannot be due to the concept of infinity not being a number. However, there is also a discussion about the emerging standard model of the universe which suggests spatial flatness and therefore an infinite extent. Some members also bring up the idea of a Big Bang cosmology and its compatibility with an infinite universe. The conversation ends with a disagreement about the validity of the Big Bang theory and its 100+ proofs.
  • #71
Originally posted by Hurkyl
(a) How does this change the fact there is still enough pressure in the depths of the sun to ignite fusion?
Just as the standard model predicted a pressure within Jupiter much greater than the galileo probe found so the sun has much less pressure than assumed by the standard model.
Astronomy news on Phys.org
  • #72
That is quite hilarious. How does the Earth stay together? What a joke!
I asked it for the sun, since you posit that the sun has a large net positive charge. Why would it be a joke?
Do you think the Earth too has a large net positive charge? There are a whole slew of problems with that one beyond simply asking how the Earth stays together.
What makes you think there are enough electrons?
The fact that there isn't an observable electric field permeating our solar system.
  • #73
The positive charge exists at the surface not all through the interior.
Non sequiter.
"This plot [... http://www.electric-cosmos.org/sun.htm] is easily measured for a laboratory plasma contained in a column - a cylindrical glass tube with the anode at one end and the cathode at the other. These two terminals are connected into an electrical circuit whereby the current through the tube can be controlled. In such an experiment, the plasma has a constant cross-sectional area from one end of the tube to the other. The vertical axis of the plot in figure 4 is the voltage rise from the cathode up to the anode (across the entire plasma) as a function of the current passing through the plasma. The horizontal axis shows the Current Density. Current density is the measurement of how many Amps per square meter are flowing through a cross-section of the tube. In a cylindrical tube the cross-section is the same size at all points along the tube and so, the current density at every cross-section is just proportional to the total current passing through the plasma.
When we consider the Sun, however, a spherical geometry exists - with the sun at the center. The cross-section becomes an imaginary sphere. Assume a constant total electron drift moving from all directions toward the Sun and a constant total radial flow of +ions outward. Imagine a spherical surface of large radius through which this total current passes. As we approach the Sun from deep space, this spherical surface has an ever decreasing area. Therefore, for a fixed total current, the current density (A/m^2) increases as we move inward toward the Sun.
In deep space the current density there is extremely low even though the total current may be huge; we are in the dark current region; there are no glowing gases, nothing to tell us we are in a plasma discharge - except possibly some radio frequency emissions.
As we get closer to the Sun, the spherical boundary has a smaller surface area; the current density increases; we enter the normal glow region; this is what we call the Sun's "corona". The intensity of the radiated light is much like a neon sign.
As we approach still closer to the Sun, the spherical boundary gets to be only slightly larger than the Sun itself; the current density becomes extremely large; we enter the arc region of the discharge. This is the anode tuft. This is the photosphere. The intensity of the radiated light is much like an arc welding machine or continuous lightning. A high intensity ultraviolet light is emitted.
Some early plasma researchers and most modern astronomers believe that the only "true" plasma is one that is perfectly conductive (and so will "freeze" magnetic fields into itself). Figure 4 indicates that this does not happen. Every point on the plot (except the origin) has a non-zero voltage coordinate. The static resistivity of a plasma operating at any point in figure 4 is proportional to the slope of a straight line drawn from the origin to the point. This means that, at every possible mode in which a plasma can operate, it has a non-zero static resistivity; it takes a non-zero E-field to produce the current density. Obviously the static resistivity of a plasma in the high end of the dark mode can be quite large. (The arc region and the left half of the glow region exhibit negative dynamic resistance - and the E-field can be quite small - but that is not what is in question.) No real plasma can "freeze-in" a magnetic field. The highest conductivity plasmas are those in the arc mode. But, even in that mode, it takes a finite, non-zero valued electric field to produce a current density. No plasma is an "ideal conductor".
  • #74
If all of the charge were on the surface of the sun, the charge could then do absolutely nothing to resist the gravitational collapse in the interior.
Non sequiter.
Good call; I don't like to say that myself, so it's nice that you prefaced your quote with the label.
Anyways, you are aware that the electric-cosmos site does not state that the sun has net positive charge; it tries to explain the resistance to gravitational collapse by a giant cooperative effort of dipoles causing the positive charge to collect in the core and negative charge to collect on the surface
  • #75
Not ALL of the charge is at the surface obviously. There are protons in each and every atom of the sun of course. The surface is just te region with the most charge density.
Ha ha. Did you even read it?
Yes that is a good point. I am not satisfied with that portion of the model either, but you will understand that there is no evidence of anything going on in the core including no evidence of nuclear fusion either. In fact the evidence says that the fusion is going on at the surface as I have pointed out with the neutrino flux. It is pure speculation on the part of ALL cosmologies as to why the sun doesn't collapse, but it is also pure speculation to assume that it would collapse. Remember also that the sun has a high degree of angular momentum. It seems fair to say that the interior is much more complex than we know and all of these factors lead to the fact that there is no evidence that any fusion reactions are going on in the core. If there were fusion in the core there wouldn't be the correlation between the neutrino flux and the sunspot density.
Physics has no clue what an atom really is and what gravitation really is as well. This is where ALL of physics breaks down as manifested in the uncertainties and singularities, the neccessity of the invention of Dark Matter and MUCH else. This is where Sorce Theory comes in, but qualitatively it is RADICALLY different from the standard model yet it fits perfectly with the fluid equations at the core which model the quantum vacuum as a zero-energy superfluid. :wink:
  • Astronomy and Astrophysics
  • Cosmology
