Number of modes in optical fiber
A single mode fiber can potentially exhibit multimode behavior if a shorter wavelength light, such as 633nm from a HeNe laser, is used instead of its designed operational wavelength of 1300nm. The calculation suggests that using 633nm could result in approximately two modes. However, the observed non-uniform mode pattern may indicate that the fiber in question is actually multimode rather than single mode. This discrepancy raises questions about the fiber's specifications and intended use. Ultimately, the characteristics of the fiber and the wavelength used play crucial roles in determining the mode behavior.
says
Can a single mode fiber become multimode if the wavelength of the light passed through it is small enough?
I put a HeNe laser (633nm) through what I thought was a single mode fiber. If it's supposed to operate at 1300nm, then would a low wavelength of 633nm cause multiple modes in the single mode fiber?
number of modes = operational wavelength / wavelength used
number of modes = 1300nm/633nm = (approx.) 2 modes?
I'm not sure why my image isn't showing a uniform mode / pattern.
Maybe you have a multimode fibre?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
