Number theory factorization proof
dancergirlie
1. Homework Statement
If n is a nonzero integer, prove that n cam be written uniquely in the form n=(2^k)m, where It is in the primes and unique factorization chapter so maybe that every integer n (except 0 and 1) can be written as a product of primes
I am not sure, but I tried to do a proof by induction on n
Let n=1
so, 1=(2^k)(m)
1=(1)(1)=1 where k=0 and m=1
so the statement holds for n=1
Now assume the statement holds for n=(r-1) for any integer (except 0 and 1)
so
(r-1)=(2^k)(m) where k is greater than or equal to zero and m is odd
Now let n=r
so r=(2^k)(m)
This is where I don't know what to do... that is why I'm thinking there is an easier way to do this besides induction. Any help would be appreciated =)
You left off the conditions in your problem statement.
After this you tell us where the problem appeared in your text. What are the conditions on k and m?
Also, for your induction proof, I would start with 2, not 1.
ohh I'm sorry
k has to be greater than or equal to zero and m is odd
Let me repost the problem, cause I see some typos...
Let n be a nonzero integer, prove that n can be written uniquely in the form (2^k)(m) for any integer k greater than or equal to zero and for any odd integer m.
If i can avoid doing an induction proof, that would be great, but if this is the only way then i guess i can do it
This might not pass muster as a formal proof, but it will help you think about this problem.
There are two cases: n is even and n is odd.
1) If n is odd, it has no factors of 2, so n = 20*n, and you're done.
2) If n is even, there must be at least one factor of 2, so n = 21*m
a) If m is odd, you're done.
b) If m is even, apply step 1 again.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
