Objects that react physically to light?
  • Thread starter Thread starter nlaham
    Light
The discussion explores the concept of objects that physically react to light without temperature changes. Participants mention various examples, including photovoltaic cells and UV-curable materials, but acknowledge these often involve chemical reactions rather than purely physical changes. A notable point raised is that light exerts a small pressure on objects, causing them to accelerate or strain. The conversation also touches on molecular changes in response to light, particularly in biological systems, while highlighting the lack of macroscopic examples that fit the criteria. Nitinol, a memory metal, is suggested as a material that can undergo significant physical transformation when exposed to light, particularly infrared, though this may still involve heating effects.
nlaham
Does anyone know or have heard of any object that will react or change physically to light (and not necessarily because of temperature)?
I know materials expand and contract with temperature, but do any materials or objects change their physical form by light or radiation alone? I thought photovoltaic cells, or even pigment in ones skin, but that seems more of a chemical reaction than a physical one.
Sunflowers?? Haha just kidding, but for real. Anything out there today of this nature.
Science news on Phys.org
Anything non-biological?
haha! I might have to buy one of those.
Although the hexbug is powered by solar cells, which is a chemical reaction right? Either way, nothing actually moves in the PV cells (except the electrons I suppose)
There are UV curable materials, but they would only get harder with more light introduced (until fully cured).
Andy Resnick said:
Vampires
Best answer yet. :biggrin:
Light hitting an object puts a pressure on that object. It's a very small pressure, but it's there. So you can say that all objects will accelerate or strain when having a light shone on them.
HAH! I said non-biological. :-p
Lsos, you don't happen to know any simplified equations off hand that relate the pressure or acceleration to radiation? Not that I could really use them for practical purposes but now I am just more curious then anything.
On the molecular level, there are many molecules that undergo conformational changes (i.e. changes in their shapes) when they absorb light of a particular frequency ... actually the mechanism of vision works this way. The retinal moeity of the rhodopsin protein absorbs a photon and changes it's conformation, which is the initiation step of the signalling cascade that let's your brain know a vision receptor was stimulated.
These types of molecules are sometimes incorporated into nanotechnology designs as light-activated sensors/switches, but I am not aware of any macroscopic systems that behave in this way, and meet the criteria you have established.
LOTS of materials break down in the long-term presence of light. Textiles, plastics and dyes readily come to mind.
Usually, it's the UV light that does the most damage.
Oxygen gas breaks down into monatomic oxygen. Lots of chemical reactions in the atmo around ozone that happen in the presence of light...
My clear vote is for Nitinol.(memory metal)
Though shinny, if coated black and hit with sufficient light, especially IR, a dramatic physical transformation takes place.
Isn't that a heating effect though? I though the OP wanted to rule those out ... although as Andy Resnick pointed out, this is largely a semantic difference for macroscopic samples of molecules.
Yes indeed. But doesn't IR qualify as a photon-enabled trigger of physical transformation in this case?
Perhaps that's not what OP intended though, as you say.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 152 ·
10K
23K
