Observing from Earth the clock in a spaceship
The discussion focuses on the relativistic effects observed when a spaceship departs Earth at time t=0 with a constant speed u. An Earth observer reads the spaceship's clock at time T using Lorentz transformations. The key equations include the Lorentz transformation for time, t = √((1-u/c)/(1+u/c))T, and the relationship between the emitted light and the observer's frame. The participant clarifies misconceptions regarding time dilation and the necessity of applying Lorentz transformations to accurately determine the time read by the observer.
  • Understanding of Lorentz transformations in special relativity
  • Familiarity with the concepts of time dilation and simultaneity
  • Knowledge of the speed of light as a constant (c)
  • Basic algebra for manipulating equations
  • Study the implications of time dilation in special relativity
  • Learn how to apply Lorentz transformations in different reference frames
  • Explore the concept of simultaneity and its effects in relativistic physics
  • Investigate the relationship between speed, time, and distance in relativistic contexts
Students of physics, particularly those studying special relativity, educators explaining relativistic concepts, and anyone interested in the implications of high-speed travel on time perception.
giuliopascal
A spaceship leaves Earth at time ##t=0## with constant speed ##u##. Its clock is synchronized with the terrestrial one. At time T an earthling reads with an optical telescope the clock inside the spaceship. What value does he read?
Lorentz equations.
The solution says:
##c(T-T_e)=u T_e##
##T_e=\frac{T}{1+u/c}## and ##X_e=\frac{uT}{1+u/c}##
Apply a Lorentz transformation:
##t=\sqrt{\frac{1-u/c}{1+u/c}}T## at ##x=0##
And ##t## is the answer.
However when I tried to solve it I considered also the time needed for light to reach the Earth from the spaceship. As a consequence my solution would be ##t'## such that:
##t'=t+T-T_e##
Is it wrong?
Thank you very much.
Can you explain in words what's being done in the solution? It appears you don't fully understand what those equations mean.
Ok, I think I have taken a few steps forward.
I misunderstood which points was the Lorentz equation applied to. I thought there was a time dilatation in ##(T_e,X_e)##, but it is wrong, isn't it? In the Earth reference frame, when the spaceship emits the beam of light the clock time is ##T_e##, without any correction. If that is true, I applied a useless Lorentz transformation, and by chance I found the correct answer.
So:
solving ##x=ut## (spaceship) and ##x=-c(t-T)## (beam of light), I find ##(T_e,X_e)##: that is when the beam of light is emitted. Then I need to go back to ##(T,0)##, where the observer is. But why do I need a Lorentz transformation with boost ##u##? (I have to use that, haven't I?)
Thank you.
So:
That's when and where the light is emitted as measured by the Earthbound observer.
As long as light is emitted at ##(T_e, X_e)##, it will reach the observer at (T, 0). The question now is what is the image that was emitted?
  • · Replies 25 ·
  • · Replies 19 ·
  • · Replies 35 ·
