Obstacle course acceleration problem
Jane's obstacle course problem involves calculating the tension in a rope as she accelerates upward at 1.50 m/s² with a mass of 55 kg. The key forces acting on her are the tension in the rope and the force of gravity, which is her weight. Using Newton's second law, the correct approach is to sum the forces: T - Fg = ma, where Fg is the gravitational force (mg). The final calculation shows that the tension T equals 622.05 N after accounting for both her upward acceleration and the downward gravitational force. Proper application of Newton's laws and free body diagrams is essential for solving such physics problems accurately.
Helpme7534
While running an obstacle course, Jane comes to a rope hanging from a platform. She grabs a rope, which then accelerates her up into the air. Her mass is 55 kg and she accelerates upward at 1.50 m/s2. The tension on the rope is ____N.
F=ma
F=55(1.50)
F=82.5 N
Is this right?
No, when applying Newtons 2nd law you need to consider the sum of the forces acting on a body.
So,
\sum F = ma
can you show me how to do a question like this?
(keep in mind i only have physics 20-1)
What forces are acting on the object when she grabs the rope?
Let me remind that we are given her acceleration in the upwards direction so we really only need to consider the vertical forces acting on the body.
the force of her and the force of gravity?
The force of tension and the force of gravity. The force of gravity can also be denoted as her weight.
Now apply Newtons 2nd law and solve for the force of tension.
F=539.55N
is that the ans?
Helpme7534 said:
F=539.55N
is that the ans?
No.
How about instead of posting one line of "Is this the answer?" you show us your work in full detail and your reasoning behind it.
Only then will we be able to truly help you.
(By the way, I don't consider handing you the answer helping)
dude i did what u told me to do i wasnt randomly posting that
but if u can't see that..
F=ma
F=her mass (aka 55kg, since you may not wan to scroll to the top)(9.81m/s2)
F=539.55 N
(yes I am grouchy but its only cus I've only been through this with other ppl who after a waste of my time can't figure it out themselves in the end, i apologize)
\sum F = ma
It's the SUM OF THE FORCES on the body that will correspond to its mass times its acceleration.
You told me there were two forces acting on her body (atleast in the vertical direction).
If you defined the y-axis to be positive upwards and negative downwards, sum the forces on the left handside of the equation according to their direction and on the right hand side simply compute her mass times her given acceleration.(keeping in mind the way you've defined your y axis)
so
(1.50)(55)-(9.81)(55)=-524.835N
T - F_{g} = ma,
You need to review/practice your application of Newton's 2nd law. Are you drawing free body diagrams when you're attempting a problem?
So T=622.05
i didnt get that from no where i went T=ma+Fg
F_{g} = mg
so T=(55)(1.50)+(55)(9.81)
Correct.
