Calculating Lottery Odds: How Are Your Chances of Winning Determined?
  • Thread starter Thread starter Gomar
    lottery
Calculating lottery odds involves understanding the difference between combinations and permutations, as the order of numbers typically does not matter in major lottery games. For example, in a Take5 game, the odds of winning the top prize are calculated based on the combination of non-repeating numbers, resulting in odds of 1:575,757. Some participants mistakenly assume that order matters, which can lead to incorrect calculations of winning probabilities. The discussion highlights that winning numbers are presented in a sorted manner for clarity, but this does not affect the outcome of the game. Ultimately, the lottery's structure is designed to allow multiple winners, which would be less likely if order were a determining factor.
Gomar
I'd like to calculate the odds of winning the lottery. Each game has posted
odds, however, my calculations give different odds. Perhaps I am not doing it right, or
they use a different method, but here are my results compared to theirs:
If we use #'s 0-9, and pick one number, then odds of winning are 1 in 10. Thus, I just have to buy 10 tickets, play all numbers, and will get a winner 100%.
If 3 numbers are picked, then it's 10x10x10, or 000-999, thus 1:1000 correct?
But, in a single Take5 game, numbers cannot repeat. Key space is 39.
thus 39x38x37x36x35 = 69,090,840
To win top prize(all 5 #'s matched), their odds are 1:575,757.
http://www.nylottery.org/ny/nyStore/cgi-bin/ProdSubEV_Cat_405_SubCat_337562_NavRoot_300.htm
How is that calculated?
Pick10 has better odds, eventhough the key space is 80. Since 20 numbers are picked(1/4), and you pick 10(1/8), top prize matches 10, you have 2x chances to win. But, that's the same odds as matching 5 to 10 if key space was 40.
http://www.nylottery.org/ny/nyStore/cgi-bin/ProdSubEV_Cat_406_SubCat_337554_NavRoot_300.htm
Winning Numbers Matched Per Game: 10
Prize: $500,000
Chances of Winning
on one Game Panel
1:8,911,711
Isnt it 80^10?
In any case, how is that any better than playing slots in Vegas or A.C.? 1c, 5c, 25c, gives more games than $1 on above. I played 1c at a casino in Vegas, and won $10; that's 1000%.
Mathematics news on Phys.org
You're assuming that order matters, that 12-32-11-15-02 is different from 32-12-11-15-02. The lottery commission assumes that order doesn't matter. (Redo your calculations with 5 numbers; you'll get 120 ways of choosing a ticket instead of 1.)
"You're assuming that order matters" - just to support CRGreathouse on this; it's easy to make this error (many of my students do so). A reason, one that they give as justification for their error, is "the winning numbers are always presented on tv/in print in increasing (or decreasing) order". That is true, but irrelevant to the game: it's done simply to make it easier for the audience to read/remember.
Ok, so are you both saying that if the winning numbers are: 34-19-2-8-27 shown on TV as: 2-8-19-27-34, I still win even if my numbers on my ticket are printed as: 19-8-34-2-27?
I saw nowhere it says order matters or not, except for Daily Numbers, so perhaps I was wrong. That explains why several people win prizes instead of just 1.
However, it would seem logical that is 1 person did indeed get the order right, only he/she should get the prize.
"Ok, so are you both saying that if the winning numbers are: 34-19-2-8-27 shown on TV as: 2-8-19-27-34, I still win even if my numbers on my ticket are printed as: 19-8-34-2-27?"
Yes - the major lottery games, the ones I'm aware of, consider the winning set of numbers: as long as you have every one of the selected numbers, you win at least a share of the grand prize.
"However, it would seem logical that is 1 person did indeed get the order right, only he/she should get the prize."
If order of selection were specified as the requirement for winning, grand prize winners would occur so rarely that the game would (pure speculation on my part here) fall quickly from favor and nobody would purchase tickets.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
