Ohm's Law and its implications
  • Thread starter Thread starter spaghetti3451
    Law Ohm's law
Ohm's Law illustrates that the resistance of a wire is directly proportional to its length and inversely proportional to its cross-sectional area. This relationship can be expressed mathematically, with voltage (V) related to electric field (E) and length (L), while current (I) is linked to current density (J) and area (A). The concept of resistivity plays a crucial role, defined as the ratio of electric field to current density. Understanding these principles helps clarify how physical dimensions of a wire affect its electrical resistance. Overall, the discussion emphasizes the fundamental relationships defined by Ohm's Law in electrical engineering.
spaghetti3451
How can Ohm's law explain the fact that the resistance of a wire depends directly on length and inversely with area?
What are your thoughts on the question?
Well, the voltage has something to do with the length and the current with the time. (V= EL and I = JA). Is resistivity the quotient of E over J?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
11K
