Oil spill: Water pressure VS. oil pressure
The discussion revolves around the effects of water pressure on oil spills, specifically in the context of the Gulf of Mexico incident. Participants explore how water pressure at significant depths influences the release and quantity of oil, considering factors such as buoyancy and pressure differentials.
  • Olivier Gagnon questions whether water pressure at a depth of 1500 meters affects the release of oil and if a shallower depth would result in a proportionally larger spill.
  • Some participants suggest that water pressure restricts the amount of oil released, but the extent of this restriction is debated.
  • There are inquiries about the buoyancy of oil compared to water pressure, with some participants noting that buoyancy effects may be minimal relative to pressure differentials.
  • Concerns are raised about the compressibility of oil at high pressures and how this may affect the flow of oil and gas during a spill.
  • One participant mentions that using denser "mud" in the pipe was intended to counteract oil pressure, but a decision to use seawater instead may have contributed to the spill's severity.
  • Another participant posits that the pressure differential between the well and seawater could be influenced by gas coming out of solution, likening it to the behavior of a carbonated beverage.
Participants express differing views on the impact of water pressure on oil spills, with no consensus reached regarding the extent to which it affects the spill's quantity or dynamics. Multiple competing models and hypotheses are presented without resolution.
Participants acknowledge the complexity of the situation, including the interplay of pressure, buoyancy, and chemical reactions at depth, but do not resolve the various assumptions and variables involved.
  • #31
Yankus said:
May I also add for pavolgrad, BP wasn't drilling anywhere. BP owns the rights to the seabed in that area, Trans Ocean was doing all of the drilling. The final decision to check the BOP was Trans Oceans. I don't know if any oil company drills their own wells, the drilling is usually handled by contractors.
So if you wish that Trans Ocean had not drilled (on behalf of BP) a well so deep (and stewartcs is right there's quite a few deepwater wells that are perfectly fine (accidents happen in this industry)) I suggest you petition the US government to stop selling rights to deepwater areas.
I agree that Transocean is partly responsible. They are actually the ones who are responsible for the safe operation of the vessel and for the safety of the crew (the OIM or Master has legal authority over the oil company).
BTW, Petrobras owns their own rigs and drills with them (in Brazil at least). I'm sure there are probably others as well...maybe smaller companies though.
CS
  • · Replies 75 ·
  • · Replies 28 ·
  • · Replies 17 ·
  • · Replies 49 ·
