I On an object's size vs distance relation
  • I
  • Thread starter Thread starter davidge
    Relation
The discussion focuses on explaining the apparent size of objects relative to distance using theories beyond ray theory, specifically Maxwell's electromagnetism and potentially Einstein's general relativity. Participants note that while ray theory effectively describes this phenomenon, it is limited and other theories can provide deeper insights. Huygens' Principle is suggested as a method to approach the explanation without relying on ray theory. However, it is acknowledged that many valid methods will yield similar geometric results, resembling ray theory. The conversation emphasizes the inherent geometric nature of the problem and the challenges in finding alternative explanations.
davidge
It's pretty easy to explain why objects appear small as the distance from them increases, if we use ray theory: as the distance increases, the angle become smaler. But I know the ray theory is far from being a accurate theory of light. My question is then, How can we explain the phenomenon of size/distance relation by using the next best theory of light that we have? I.e. using Maxwell theory
Just to say, I was driven to this question after reading about the Solar Eclipse that will occur later on this month.
Likes davidge
Say I want to explain the apparent size of objects that are some hundreds of meters away from me. In that case, I guess using Einstein's Relativity would be too hard as we are on a planet (Earth) with plenty of matter around us, etc... It would be definitely more easy to go with Maxwell's electromagnetism. The question then is, How do we proceed?
Find a wave solution to Maxwell's equations. Then use wavelet theory to see how waves propagate in straight lines. Then realize that ray optics is still a tool that gives correct answers.
Likes CWatters, russ_watters, davidge and 1 other person
Ok, that's great, but my goal on this thread is to find a way of explaining the given phenomenon independently of ray theory :frown:
Google for Huygens' Principle. It's basically step 2 in jbriggs444's plan.
Likes davidge
That is indeed what @jbriggs444 outlined. The "problem" is that the answer is inherrently geometric so pretty much any valid method will end up giving approximately the same result and looking a lot like ray theory.
It's like what happens when you apply General Relativity to low speed or static situations: it automatically simplifies to Newton's law of gravity whether you ask it to or not.
Likes CWatters and davidge
Oh, ok. Thank you all. I will read something on the subject.
