Proving the One Sided Limit Theorem: A Rigorous Approach
  • Thread starter Thread starter RPierre
    Limit
RPierre
Prove that the limit as x->c of f(x) = L if and only if both one sided limits also = L
Has to be an epsilon delta proof
Being an if and only if, I have to do two cases : If A, then B. and if NOT A, then NOT B, logically.
Case 1:
Let lim x->c from the left be L, and lim x->c from the right be L.
then if c - \delta < x < c then |f(x) - L| < \epsilon
and if c < x < c + \delta then |f(x) - L| < \epsilon
Case 2:
Let lim x->c from the left = M, and lim x->c from the right = N.
This is all I have really rationalized I am kind of stumped how to do a rigorous proof of this, I.e. I know how to do specific proofs but not a rigorous general proof. \
Can anyone offer any help / a starting point =/ ?
Okay, we have two things to prove: 1) if f(x) goes to L as x goes to c, then both one sided limits also approach L. 2) If both one sided limits go to L for x approaching c, then f(x) goes to L as x goes to c.
For 1) we know that for every positive epsilon, there exists a positive delta such that |f(x) - L| < \epsilon if |x - c| < \delta. We can rewrite |x-c| < \delta as c - \delta < x < c + \delta. Now, say we're examining the right handed limit of f(x) as x->c, then we only look at the interval x < c + \delta, right? And with the left handed limits we only look at the interval c - \delta < x. You should be able to prove it now.
2) Look at the delta-interval of both one-sided limits and "put them together".
Is it possible to continue the solution? I can find the (1).
For 2), you're going to assume that both one-sided limits exist. So for every positive epsilon, there is a positive delta such that c - x < \delta \Rightarrow |f(x) - L| < \delta and x - c < \delta \Rightarrow |f(x) - L|.
Put the two delta inequalities together to get c - \delta < x < c + \delta \Rightarrow |c - x| < \delta \left, which we know implies |f(x) - L| < \epsilon.
thnxxx mate.. I found it after a while... have a nice day...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
