Is there a unique solution to the given ODE?
  • Thread starter Thread starter TheForumLord
    Ode
TheForumLord
Given This ODE:
y' = (y-2) (x^2+y)^5
y(0)=5
A. Show that this problem has one solution that is defined in an open segment that contains 0.
B. Let y(x) be a solution for this problem. Prove that y(x)>2 for every x in I and conclude that y'(x)>0 in I.
Hint: You can use the solution of the problem: y'=(y-2)(x^2+y)^5 , y(x0)=2
Help is needed !
TNX!
This is of the form y'= f(x,y). Your f, (y-2)(x^2+ y)^5, is differentiable in both variables in any region that does not include (0,0) so you can use the "existence and uniqueess" theorem.
Further, since y(0)= 5, y'(0)= (5-2)(0^2+ 5)^5> 0 and y'(x)= 0 only where y= 2 or y= -x^2. The latter is impossible so any max or min must be at y= 2. Since the initial value is 5, the derivative is positive there, and can become negative only at y= 2, the function is always larger than 2.
Hey there HallsofIvy,
There are some things I didn't understand in your answer:
The initial value is 5 indeed. and from y=5 the function goes up. But how can we know what happened before y=5? Maybe there was a point that was less then y=2? There can be an inflection point in y=2, and then there are values less than y=2...
How can we solve it?
TNX in advance!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
