Will an Op-Amp Output Maximum Voltage with V+ Connected to I+ and V- to I-?
Connecting V+ to I+ and V- to I- in an op-amp can theoretically yield maximum output voltage, as op-amps typically have high open-loop gain, amplifying any differential voltage significantly. However, real-world constraints, such as output saturation limits and input voltage ranges, can affect this outcome. While many op-amps can drive rail-to-rail outputs, some may not allow inputs to approach the supply rails without producing erroneous outputs. It's important to note that operating an op-amp without negative feedback is generally discouraged, except in specific applications like oscillators. Overall, while the output may remain high, it will be slightly less than the maximum due to inherent voltage drops in the output stage.
matejhowell
Ok, I just want to see if this would work (but never tried it).
Given a standard (though not ideal, let it be real world) op-amp, it has 5 main inputs -- I+, I-, O, V+, V-. If no loops were formed, and V+ was connected to I+ and V- was connected to I-, would the output O always be the maximum voltage on those two pins? What are some real world constraints?
Normally, this is a comparator, letting V+ pass to O if I+ > I-, and V- pass to O if I+ < I-. But just thought of this twist, didn't know if anyone had some thoughts...
MLH
Yes, in theory and generally in practice, because most op-amps have an open-loop gain of atleast >100. This means that any differential voltage seen across its input will be amplified 100 over times (over the saturation voltage). Since the output cannot go beyond saturation, it will always be in saturation. Usually, some bias currents (due to the non-ideal nature) is enough to make the output go to saturation. This also means that, it is never recommended to turn on an op-amp without negative feedback (unless you're using it as an oscillator which will require postive + negative feedback). Op-amps in saturation == very hot.
Nah. The only thing that will make an opamp hot is if its output current spec is exceeded, which you're not going to do when you pin the output open circuit one way or the other.
As for the OP's question, yes, the output will stick high given the input biasing that you describe, but it will be "high" minus some voltage that depends on the output transistor structure. Take a look at the equivalent circuit for a typical opamp (usually included on the datasheet), and you'll see basically what the output stage looks like. Many CMOS opamps will drive rail-to-rail at the output.
Keep in mind also that especially for many comparators, the input voltage range may not include the rails. So if you pull one or both of the inputs too close to the rails, you may get a nonsensical output voltage.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
