Op-Amp Circuit Analysis: Voltage and Current Calculations with R1 and R2
The discussion revolves around analyzing an op-amp circuit with specific resistor configurations (R1 and R2) and determining the relationships between input and output voltages and currents. Participants explore various aspects of circuit behavior, including voltage at the non-inverting input, current through resistors, and the classification of the amplifier as inverting or non-inverting.
  • Homework-related
  • Some participants express confusion about whether the circuit is a non-inverting or inverting amplifier, noting the connections to Vout.
  • One participant proposes that the voltage at the non-inverting input (V+) can be expressed as Vout/2, while another challenges this by stating that V- cannot equal Vin due to the voltage drop across R1.
  • Another participant derives the current through R1 as (Vin - 0.5Vout)/R1 and attempts to find Vout using Kirchhoff's law, but expresses uncertainty about sign conventions.
  • Discussions arise about the implications of grounding R1 and how it affects V+ and V-. Participants explore the flow of current through R1 and R2 and the resulting voltage drops.
  • One participant mentions input bias current and its effect on the op-amp's behavior, suggesting that it can lead to an input offset voltage.
  • There are attempts to clarify the relationships between the voltages and currents in the circuit, with some participants providing practical examples to illustrate their points.
  • Confusion persists regarding the correct expressions for Vout and the impact of the additional feedback resistor connected to the non-inverting input.
Participants do not reach a consensus on several points, including the classification of the amplifier, the correct expressions for voltages and currents, and the implications of grounding certain components. Multiple competing views and uncertainties remain throughout the discussion.
Participants express confusion regarding the sign conventions in Kirchhoff's equations and the impact of the feedback resistor on the circuit analysis. There are unresolved questions about the relationships between the input and output voltages and the behavior of the op-amp under different configurations.
This discussion may be useful for students and practitioners interested in op-amp circuit analysis, particularly those grappling with concepts of feedback, voltage/current relationships, and the implications of circuit configurations.
thercias
Consider the circuit drawn below
This diagram was the closest I could find online to the one equivalent to my question, but there are some adjustments I need to clarify.
1)Replace Rz, Rf, and Rin, to R1.
2)Also, in my question, there's an extra wire connecting Vout to the right of Rz. In this wire, there is a resistor in the middle, called R2.
3) Switch the + symbol to the negative side and the - symbol to the + side.
Edit: Here I redrew it in paint to give a better illustration of the circuit:
Now for the question:
A) In terms of Vin, Vout, R1, and R2, what is the voltage at the non-inverting input to the op-amp (v+)?
B) In terms of Vin, Vout, R1, and R2, what is the input current to the circuit ( the current through R1)?
c) In terms of Vin, R1, and R2, what is the output voltage (Vout) of the circuit.
Kirchoff's loop equations
V+ = V-
V= IR
I guess something I'm confused about in this question is if this is considered to be a non-inverting or inverting amplifer, since the wires go from both sides of Vout.
A)
So one of the main rules for op amps is that the voltage at the non inverting input will equal the voltage of the inverting input. This can be solved by using a voltage divider.
Therefore, at Voltage at the non inverting input, V+ = Vout(R1/(R1+R1)) = Vout/2
Also V+ = V- = Vin can be another way to express this. Therefore we also get the expression Vin = Vout/2
However, I'm not sure if this is correct, since the question wanted it in terms of 4 variables, while I only have it in terms of Vout.
B)
current = i = (V(-) - Vin)/R1 =[Vin-Vin]/R1
So the current cancels and becomes 0, which doesn't make sense. So something is wrong with part A.
I'm having trouble finding the voltage through the non inverting input for starters, so if anyone can help me through that it would be appreciated.
There's no reason why V- is equal to Vin.There's a current going through the R1 connected to Vin, so you get a voltage drop.
Ok so I redid that bit.
So we have V(-) = Vout/2
Using kirchhoffs law, the current through the R1 would be
Vin - IR1 - Vout/2 = 0
therefore, I = (Vin - 0.5Vout)/R1
and Vout would be
-Vout/2 - IR2 = Vout
Vout = IR2/1.5
=-R2(Vin-0.5Vout)/1.5R1
Would this be correct? I'm kind of confused when or not to use a positive or negative sign when making kirchhoffs equation for Vout/2
where is the signal being fed into ? the - input so that tells you that the circuit is an _______
you fill in the blank
It would be an inverting amplifier. So, the most difficult part for me in understanding these circuits is coming up with an expression for V+ or V-. For some reason I'm just not grasping some fundamental concept,no matter how hard I try and research. If R1 is grounded, how would that affect V+? (I understand I already solved for V+, but still trying to understand this conceptually).
Also, how does my above solution look.
you should have labelled your resistors differently
having 3 x R1 's is somewhat confusing when you ask Q's or someone tries to explain
for a moment ( partly because I have never seen 2 feedback resistors --- a little unsure how to attack that ;) )
lets ignore the R1 feedback resistor to from output to +in
if +in is grounded, then the op-amp will follow the rule that it will do what it can to make -in = +in so if +in = 0V, -in will = 0V ( when its in closed loop mode ie. there is feedback)
current I, through the input R1 = Vin / (input)R1
now remember the other op-amp rule ... NO current flows in or out of either input
so where is the current flowing ? through input R1 and ______
Current is flowing through R1 and R2. But they are separated by a junction. So would I = Vin/R1 = Vout/R2 ?
And V(out) = V(-) + IR2?
edit: I wouldn't be Vout/R2, it would be V2/R2
yes but treat each part separately
initially you work out the current through input R1= Vin / (input)R1
that current cannot flow into the -in input of the op-amp so it flows up and through R2
That will produce a voltage drop across R2 = ______
you are maybe seeing that this can all be done with Ohms law :)
Have you learn about input bias current of an op-amp yet ?
if so we can then explain the resistor from +in to ground
Voltage drop across R2 = IR2 = VinR2/R1
So Vout would be = Vout/2 + VinR2/R1
Vout =2VinR2/R1 ?
I just saw your question
Is the input bias current difference through the current from the + and - inputs?
As for explaining ground, I think this example is kind of hard to understand since the R1s get in the way. For something like this,
The resistor is being grounded. Does that mean the voltage through the - input simply becomes the output voltage? And would the voltage across the resistor also be Voutput then? And the voltage through the diode be v input?
lets put some practical values in here ( I work easier that way )
Vin=1V, R1 = 1k, R2 = 10k
so I through R1 = 1V/1k = 1mA
V drop across R2 = I x R2 = 1mA x 10k = 10V
The R1, R2, -in node is going to be positive relative to the R2, op-amp output pin
so we know that the R1, R2, -in node is 0V, that means the output of the op-amp is going to be -10V ( relative to the input)
follow that ? :)
Input bias current ...
as per the rule ( Ideal op-amp) No current flows in or out of the op-amp inputs
in reality, ALL op-amps have a very small input bias current --- nano to micro amps
This results in an input offset voltage ( a voltage error) between the input pins.
the input bias current applies equally to both inputs. This is the reason for the resistor connecting the "+" input to ground. If this resistor is close in value to the parallel combination of R1 and R2 the same voltage error will be generated at the two inputs, and will therefore be canceled out, or very nearly to the point of making it unimportant..
For many general applications, the input bias current is so small that any offset voltage error can be ignored. Its only when you are dealing with high gain and low noise applications ( eg preamplifiers) that you want to eliminate that error voltage as it only adds to the noise figure of the circuit
Dave
Unfortunately, I'm not really understanding. So if my answers for part A) and B) are right, I don't understand what is going wrong with part C).
Current through R1 = Vin/R1. Voltage drop across R2 = IR2. Therefore the voltage drop across R2 = Vin*R2/R1
I also thought, applying kirchhoffs rule, V(-) + IR2 = V(out).
Now all that discussion should cover everything EXCEPT the additional feedback resistor to the +in pin
As I said earlier, I haven't come across that example and not sure how to help explaining that
hopefully some one else will chime in :)
D
yes, but more simply ...
thercias said:
Vout =2VinR2/R1 ?
no ... if you plug in the values I used as an example you will see it gives the wrong answer ( twice the value ... 20V instead of 10V)
now remember what I said a couple of posts ago ...
The R1, R2, -in node is going to be positive relative to the R2, op-amp output pin node
so gain ( because its an inverting amplifier) = -R2 / R1 = -10000 / 1000 = -10therefore ... + 1V in = -10V out, -1V in = +10V out
time for bed for me here in Australia
will check in tomorrow morn :)
Okay got it I think. I was getting jumbled up with the original question when writing down my answers. Vout = -VinR2/R1 in that case I think.
Thanks for the explanations, and have a good night's sleep.
Like you pointed out, I would appreciate if someone would chime in and verify if these answers are correct, or how I can work through them if they are incorrect:
A) V- = Vout/2
B)IR1 = Vin - V-
I = (Vin - V-)/R1
C)V(-) + IR2 = Vout
0.5Vout + R2(Vin-0.5Vout)/R1 = Vout
0.5Vout = R2(Vin - 0.5Vout)/R1
0.5Vout(1+R2/R1) = Vin*R2/R1
Vout = 2Vin*R2/R1/(1+(R2/R1))
=2*R2*Vin/(R1+R2)
These are indeed all correct
